Question about Garden
Toro Lawn Mower side discharge spring
How do you attach the side discharge spring that holds the side discharge door down? It came detached and I can't figure out how to place the spring where it holds the door tightly down. So you can attach the side discharge chute and it will stay tightly secure. I've searched everywhere.
2 Suggested Answers
vincob
  • 718 Answers
SOURCE: Spring which holds the rear discharge "gate" tight
Go jackssmallengines.com browse around and you find what you seek. Good Luck...
Posted on Jul 20, 2011
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 | Toro Garden
How to replace grass deflector
I have provided a link on how to change the discharge chute on a walk behind lawn mower. It is usually pretty straightforward across manufacturers so it should be of help to you.
But in quick terms, you lift the chute cover that holds it in place, remove your current deflector, and insert a new one! It's easy!
Best of luck!
How to Replace the Discharge Chute on Toro Walk Behind Lawn Mower
Jul 14, 2015 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have trouble starting a toro walk behind mower
All,
I thought my carb was shot, so I replaced it. Still, start but no run (and had to use starting fluid). THEN!!! I noticed the spring to the "rev limiter" (just below and towards rear of carb) was not "tight". The stupid bracket that holds the end of that spring had been bent down ~1/16" and that caused all this heartache. CHECK YOUR REV LIMITER!!!
Aug 18, 2014 | Toro Power Lawn Mower
Toro Lawn Mower
tis not a toro but they all go by the same principle.
hope this helps
https://www.youtube.com/watch?v=wYaKYwVUW0c
Jan 22, 2018 | Garden
Torro Lawn Mower side discharge spring
There are 2 bolts with nuts that mount the spring/door assembly to the mower deck.
Jul 08, 2013 | Garden
Hourglass appeared on on my toro lawn mower and my blades no longer work.
Check for broken springs ontop of the mower deck these tensioner springs break after a while sometime you can use pliers to uncoil the spring a little and re-attach and use it untill you can get a replacement spring.
Sep 22, 2011 | Toro LX423 20HP Lawn Tractor 13AX90RS848
Jul 19, 2011 | Toro Power Lawn Mower
When I hold the bar down that engages the blade my hands hurt .
There is a possibility that the spring one of the ends of the cable attached to the bar you are holding has stretched causing you to have to grip it harder to make the mower work. First try taking the end loose from the bar and tying a knot in it to make it a bit shorter. This usually works, but you may have to replace the cable.
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
