My floor on the passenger side filled up with water. Now the a/c in the vehicle will not turn on. When excelerating cold air will blow out but once stopped there is nothing.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
There is a drain tube which channels the water the ac produces .That's the water you see under the car. Could be something's blocking the tube
Posted on Jul 08, 2013
jumptrout51
  • 3361 Answers
SOURCE: A/C - Passenger side cold, Driver side hot
Probably a bad vacuum line not opening the damper vent.
Posted on Apr 22, 2009
SOURCE: LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Posted on Sep 13, 2009
  • 4 Answers
SOURCE: Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
Posted on May 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: it blows cold air for 5 min. and the it blows cool air for 15 min
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
Posted on May 22, 2010
heatman101
  • 43501 Answers
SOURCE: Danby DPAC7599 Air Conditioner is not blowing cold
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
HEAT ONLY BLOWING WARM AIR ON PASSENGER SIDE
have someone check the driver's side temperature control doors, in behind the radio. there are two push rods attached to a plastic piece. the connector on one or both of these push rods, become unattached. leaving you with cold air. once that temperature door is closed you get hot air. passenger side still mixes, but not drivers. All or none for heat on Driver's side
Dec 12, 2011 | 2005 Kia Amanti
THE DEFROST BLOWS OUT HOT AIR, BUT THE FRONT SIDE WINDOWS AND THE TOP OF THE WINDSHIELD FOGS OVER. HARDLY ANY AIR COMMING OUT OF THE VENTS ON THE SIDE OF THE DASH THAT BLOWS ON THE FRONT DRIVERS SIDE AND...
You didn't specify what type of vehicle.
If you have very poor air flow out the vents, later model vehicles have a hepa filter or cabin filter in line form the blower motor to the vents. It can be plugged quite easily and drastically cuts down the air blown into the vehicle. Check to see if they are plugged. Secondly, Check your coolant level in the rad and reservoir. If the windows fog up when cold and air flow is good it could indicate a leaking heater core. Check the passenger side floor for signs of coolant again I don't know the type of vehicle, some heater cores are located at the firewall under the hood.
Jan 31, 2011 | Oldsmobile Intrigue Cars & Trucks
WHEN I TURN ON THE HEATER THE DRIVERS SIDE HEATS UP AND THE PASSENGER SIDE ONLY BLOWS OUT COLD AIR. THE A/C MAKES A HUMMING NOISE WHEN I FIRST START CAR? AND THE RUG USE TO GET WET ON PASSENGERS SIDE.
does you vehicle have the dual climate control on each side?? where you can choose how hot your air is, and the passenger can set theres?? when the floor gets wet thats usually a positive sign that the heater core is bad.. im not exactly sure how your lexus is set up, but id say either you have a heater core bad, or the blend door for the passengers side is stuck.. thats only possible though if there is indeed dual climate controls.. hope this kinda helps
Dec 07, 2010 | Lexus GS 300 Cars & Trucks
Passenger side only blowing cold air.
You need to replace the "blend" door actuator motor on the pass side. I recommend getting that from your nearest gm dealer to ensure proper fit. When you adjust the air from cold to warm to hot, the blend door moves to direct the right amount of cold, or warm, or hot air your desire on that side of the vehicle
Dec 04, 2009 | 2000 Buick Regal
Wet floor on passenger side in front and the extended part
The ac box is filling up with condensation.The drain ,is under the firewall,under the ac lines going inside the vehicle.Take a small diameter wire,and run it in the drain,back,and forth,until it clears,it will run out like a water fall,so look out.If this doesn`t work,then use compressed air to blow in the drain.
Oct 06, 2009 | 2000 Dodge Ram 1500 Truck
Passagenger side floor gets saturated with in think condensate. It fills up the rear passanger floor. I tried blowing out the drip line but no luck?
check under the dash on the passenger side of vehicle you should see a tube for the a/c check to make sure that it is still attatched it sounds as if the water is running under the carpet to the rear of the vehicle hope this hopes you.
Jul 11, 2009 | 1996 Chevrolet Impala SS
1999 cadillac Deville cold air blowing out passenger side vents
Sounds like a Blend door issue, but could be the controller switch, Test ALL modes of operation to see what works and what does not. That should narrow it down a bit. The Blend doors are flap/ doors that regulate air flow, newer vehicles are plastic - electric assemblies ...prone to failure. Any clicking or thumping noises during switching modes and on-off suggest a bad Blend door. Hope that helps...good luck
Jan 12, 2009 | 1999 Cadillac Seville
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
