Question about Irons
My russell hobbs steam iron 17880, the waters heating up and pumping into iron but iron not heating up, heellpppp!!!
smilemaker
  • 790 Answers
SOURCE: Faulty Russell Hobbs Steam Iron
http://www.ehow.com/how_2067318_fix-nonelectric-steam-iron.html
Posted on Jan 01, 2008
  • 378 Answers
SOURCE: no steam
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Posted on Jan 04, 2009
bozcro
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
  • 96 Answers
SOURCE: no steam from iron
check the dial is in steam position or maybe you may have build up in the line for the steam
Posted on Dec 13, 2009
SOURCE: my steam station russel hobbs iron 2200 is
You need to descale, use weak water and Vinegar solution.
www.theanswerbank.co.uk/Home-and.../Question127676.html
Posted on Mar 19, 2010
My Russell Hobbs smart glide iron as stopped releasing steam can you help
Most irons that stop working are a result of minerals deposited inside.
(As the water turns to steam, it leaves mineral deposits inside.)
There may be a chemical you could put in it to remove the minerals,
check on-line or in a public library to see.
Some folks use "distilled water only" to slow this process.
God bless your efforts.
Mar 20, 2018 | Russell Hobbs Irons
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
Instrution manual for russell hobbs 17880
i need an instruction booklet for a russell hobbs steamglide iron model number 17880 any helpers please .
Jan 20, 2012 | Russell Hobbs Irons
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
Aug 10, 2009 | Irons
Irons Logo
22 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
