Question about Fedders C48ACD1VF Split System Air Conditioner
What kind of replacement compressor
My mother's compressor (bristol h21j38babca, part 750178) is kaput. The unit no. is c48acd1vf. What knid of compressor can I replace the burned out one with? Is a 4 ton model too big? What brands would be compatible?
Compressor only stays on for 2-3 minutes than shuts off
if the sensors are okay, it might be the compressor overheating, my portable ac (moretti elite ac) is also behaving the same, especially when i turn the fan to max. the compressor shuts down about 7 mins and turns on again in about 5 mins, now i found out when i turn to medium or low the compressor runs normally. i think when on medium or low setting some of the cool air directs/channels to the compressor thus cooling it more.
Jun 03, 2013 | Frigidaire FAP094P1Z Portable Air...
I HAVE A KITCHEN AID MODEL NUMBER KSRA25FKSS00 and it is not cooling
have you replaced the ptc overload/relay on the compressor,as this is the actual start and run component that the compressor needs or it wont start or run,remove it by unplugging it off the compressor and a good sign if its bad is it will sound loose like pieces loose inside the ptc unit,you should also replace the run capacitor connected to this component too
Nov 29, 2012 | Refrigerators
Hi.. heatman101, I need a replacement for a dual capacitor, its made by aerovox, it is round & looks like its made of gray pvc plastic. im not sure if this is the part # printed on it (SH 1238). it...
If you have the # off the compressor, you can contact the manufacturer,(Bristol, copeland , etc)
they can tell you by figureing out the horsepower.or your local supply house can do it for you.
Jul 27, 2011 | Heating & Cooling
Unit ices up and quits cooling
There are a couple of things that contribute to the problem you're experiencing:
1. A dirty or clogged air intake filter. Turn unit OFF, remove and clean the filter. If filter is washable
be sure filter is thoroughly dry, before reinstaling it.
2. Cooling fins are dirty. Turn unit OFF, remove the outer shell of the AC unit, if necessary and
clean the fins with an old toothbrush and a vacuum cleaner.
3. Humidity level in your area is extremely high. This is Mother Nature's problem and is not readily
solvable.
4. Defrost sensor is not functioning properly. Replace sensor.
5.. Low refrigerant gas in the AC's compressor. Have compressor recharged.
Hope this helps you trouble shoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Friedrich TwinTemp EL24J35A Air...
I want to know the size of the compressor
G'day
.To give you a rough idea.
Each one horsepower of motor, will give about 4 cubic feet per minute.
Without the make & model of your compressor or motor type & size I can't be more spacific I'm afraid.
Kind regards Andrew Porrelli
May 11, 2011 | Air Tools & Compressors
Have a bristol compressor fitted to a prototype air con unit designed for military application, been through a TUV vibration test and failed due to pipework failing, pipework repaired, pressure tested,...
Please check your compressor pumping.
How to check?
Keep pressure gauge in discharge pipe and also keep open suction pipe, test run. It builds the pressure up to 300 psi or slightly more than that. If it's less than 275psi, it's defective.
Dec 15, 2010 | Heating & Cooling
What compressor do i need
The compressors that come in units change from year to year and model to model. Depending on the age and type of unit, it could be a Copeland, Bristol....just about anything in the 2 ton range.
Best bet would be to look down and on the top or side of the compressor, you should see a series of numbers that have the model and serial numbers. The model would be the compressor you seek and the serial will help to determine the age of the compressor. Also be sure to look for a name brand such as Copeland, Bristol, Tecumseh, etc.etc..
May 25, 2010 | Goodman CPLE24-1 Air Conditioner
Fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Jan 06, 2010 | Fedders C48ACD1VF Split System Air...
Unit will not power up . there is no power light lit up but power is live
ok..that's good. so the power supply is supplying power to the mother board. just a chance on this one..carefully, after you ground your hands on metal case, remove the memory sticks, and DO NOT touch the gold fingers..re insert them back in the slots, and see if that helps. if not, then it appears the mother board is kaput, and will need replacing.
Nov 29, 2009 | HP Media Center m7070n (HPM7070NPS590AA)...
Fedders C48ACD1VF Split System Air Conditioner Logo
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
