Question about Miele WT945 Front Load Washer / Dryer
Inlet valve & hoses
Our WT945 is filling too slowly and stopping with flashing red LED after about a minute. I'm guessing that it is the triple solenoid valve that is at fault - or am I wrong? If so, how do I get the hose clips off to check flow? Do they need a special tool? Can I just use jubilee clips?
zaids
  • 456 Answers
SOURCE: The ?Check ? indicator lamp is flashing, but hoses & filters look good
complicated
Posted on Dec 17, 2007
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
  • 70 Answers
SOURCE: Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Posted on Mar 29, 2010
  • 251 Answers
SOURCE: miele w435 soft-tronic check drain check inlet
Hi - Try this empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check & assemble - try & see if it will work.
Cheers
Posted on Jul 02, 2011
I currently own a BOSCH Dishwasher approx 2.5 years old. It just runs for 3 minutes then stops and starts again - red LED light by Tap icon flashing
Hi, that sounds like you have a fault in the water inlet valve. Best get checked or replace the water inlet valve.
Mar 27, 2016 | Bosch Dishwashers
"Check inlet/outlet indicator light" flashing
If he has takin the fill hoses off the unit and tested them for flow and the filters on the water valve are clean, then yes the fill valve would need changed.
Mar 01, 2016 | Washing Machines
Amana tandem front loader.model number
That's an F8E1 error. It means you are experiencing long fill times. Check your water and associated hoses coming in, also try to clean out the screens on the water inlet valves.
Oct 14, 2014 | Washing Machines
LG WM1814CW washer - doesn't fill with water. Hear a hum when it should be filling with water, but no water and no error codes. I am guessing Valves (F160 and F170). Any thoughts?
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 08, 2011 | LG WM1814CW Front Load Washer
Water continues to run into the washing machine through the whole wash cycle and even when the machine is off. I have to keep the tape turned off. other than that the washing machine functions normally.
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Dec 17, 2010 | Washing Machines
Hi, I have a F & P top load washer (model GW701-U) over 10 years old. I use cold water washing. The water fills up very very slowly- just dribbles. After about 7 minutes of the water filling up, the...
Turn off the water to the washer, unscrew the hoses ( do one completely before moving to the other)Once you unscrew the first hose you will see a small filter screen inside the opening on the washer,Remove the screen and clean it, replace it and reattach the hose,Now go to the other hose and do the same thing, once both are done and hooked back up, turn the waterback on and everything should work as normal.
Dec 02, 2010 | Fisher and Paykel Washing Machines
It keeps stopping flashing LF,I don't have the manual,what does LF mean?
Hello there:
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. furthermore please check the following that may apply
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet
Aug 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
Miele wt945 fills with water when switched off
this sounds like a faulty inlet valve as they should only allow water to enter the unit when an electrical signal is sent to the valve. you would need to replace the inlet valve. As it is a washer/dryer make sure you replace the correct valve which is the one on the left
Jan 23, 2010 | Miele WT945 Front Load Washer / Dryer
Feb 24, 2008 | Miele WT945 Front Load Washer / Dryer
Miele WT945 Front Load Washer / Dryer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
