Question about Maytag Legacy Series Top Load Washer
Maytag Legacy Series Electric Dryer
My electric dryer does not stop automatically. What do I do besides manually stopping it?
May need a new timer, I had to replace mine, easy job if you watch the video online.
Posted on Aug 23, 2013
  • 183 Answers
SOURCE: Maytag MAH550 washer and MDE5500 electric dryer Manuals
not available, try direct to maytag although they usually do not release to the public
Posted on Dec 27, 2007
  • 1073 Answers
SOURCE: dryer not heating, heating coil is find
check the high temp fuse on the right side of the heater housing, it has 2 white wires connected to it is about the size of a dime, it should with a meter on resistance show resistance if it is open or bad meter will not move part number is la-1053
Posted on Apr 11, 2008
  • 85 Answers
SOURCE: Dryer won't turn on
sounds like the bearings on your motor are going bad
Posted on Dec 14, 2008
kakee
  • 1269 Answers
SOURCE: I need operators manual for Maytag washing machine and dyer
Try to get it HERE
Posted on Jan 01, 2009
SolutionGuy
  • 331 Answers
SOURCE: I have a Maytag Legacy gas dryer that won't heat
OK, Crispy... the con census is that the coils have failed. The coil kit you'll need is part number 279834 and can be either purchased on line or at your local appliance parts retailer.
{{{UNPLUG THE DRYER BEFORE PROCEEDING!}}}
The repair is easy, remove the lower service access panel by removing the two screws located on either side at the very bottom. Then rotate the panel toward you and pull it out.
At the bottom right, you'll see the gas valve. There are 2 round, black coils mounted to it. One of these has 3 wires going to it and the other has 2 wires. You'll also see that they are held down by a brass colored bracket. Remove the wires from the coils and then remove the brass colored bracket with a stubby (short) Phillips screwdriver. NOTE THE POSITION OF THE COILS AND NOTE WHERE THE WIRES GO!
Install the new coils and bracket them down. Install the wires to the coils. Now rebuild the unit.
Easy breezy. Even if you've never done this, you're looking at MAYBE an hour... maybe.
Hope this helps,
SG
Posted on Mar 25, 2009
Maytag legacy series quiet 100 electric dryer. Nothing. It is just dead. All power is connected properly. Just stopped working.
try looking on the back and on the bottom of the dryer and see if there's a reset button there
Dec 12, 2014 | Dryers
I have a Maytag Legacy Series Electric dryer Mod # MDE508DAYW. The drum turns just fine but it is not heating up. I have had this dryer for approximately 3 yrs, 2 of which was in storage and not in use. I...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[]
Aug 09, 2011 | Dryers
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
110v or 220v ?
That would be a 220v dryer...virtually all electric dryers are 220v.
heatman101
Apr 19, 2010 | Maytag MDE2400A Electric Dryer
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Apr 23, 2009 | Maytag Dryers
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Washing Machines Logo
140 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
