Question about Boating
5hp gamefisher outboard motor
How do I check the points on a gamefisher
2 Suggested Answers
  • 65 Answers
SOURCE: where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
Posted on May 08, 2009
Install ignition points on 9.9 gamefisher
remove flywheel remove old points and install new set. set gap ,replace flywheel,
Oct 21, 2014 | Light Outboard Motor Boat Bass Fishing...
I have an old 15hp gamefisher that's not getting fire
Have u got spark ? Put new fuel in flushed carb and fuel lines ?
Mar 18, 2014 | Light Outboard Motor Boat Bass Fishing...
New 5 hp LEHR propane outboard motor requires 4 pulls to start. Not reliable at low revs, misses and stalls.
You need to adjust the needle valve that controls the propane into the carb, Lehr website has videos about this, its real simple, you need to add more fuel than reset your idle speed, mine needed the same thing, these motors need adjustment at time of sale and many places do not do it.
Aug 20, 2013 | Lehr Propane Powered Outboard Marine...
Briggs and Stratton Outboard - There was a response to a previous question which suggested that it was possible to lock up the lower end of one of these outboards. I have a 5hp Briggs & Stratton...
drain the g/box and see what comes out.if its got water and oil mixed,Id try for a claim.being aircooled motors,there should be no problems for long time,no impellors,just a B
Sep 18, 2010 | Boating
I bought a 5 HP gamefisher outboard motor. It 's been use once and then it sit for years outside. I change the spark plug,clean the carburator,fuel filter looks good.good compression. gas go all a way to...
If spark plug is dry, fuel is not getting to the cylinders. Next thing to check would be the fuel pump... Gas may be getting to carb, but the pump needs to push it into the cylinders too.
Oct 18, 2009 | Boating
Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
May 05, 2009 | Boating
Water circulation (coolant) thru outboard motor
Common problem is the thermostats staying closed. If i remember correctly they should be replaced every year. Water should be spitting out on the upper part of the shaft. Good luck on that fishin'
Apr 25, 2009 | Boating
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
