Question about Radio Communications
Icom 2sra circuits - Radio Communications
  • moshe2211
    moshe2211 Jul 08, 2013
    circuitc electronics icom 2sra
Icom f5021 blows power fuse Does it have a protection diode
should have one where the power wires come into the set. For the price of this radio it better have one.But thats not nessarily why it blows the fuses.It could be a power transistor thats blown or even the driver for it.Could also be an IC circuit.
May 15, 2014 | Icom F5021 Vhf Mobile 50w 128ch W Magnetic...
ICOM 802 NOTRECEIVING
Check the speaker .it may be busted. If you hear any sound your receiver circuit is faulty
Dec 21, 2013 | Icom Radio Communications
Icom u16 Rx , but when I Tx , speaker makes buzzing noise , could the antenna connection to the pc board be bad ?
It's possible because this would allow the RF signal to flood the circuit. I would suggest you try another antenna as a first solution. A bad antenna would cause the same problem. Good luck and let me know if it helps!
Sep 18, 2013 | ICOM Informatique Icom Radio U16, IC2GAT,...
IC-736 total failure whilst on air, fuse OK, nothing smelt burning etc, not over heated, no voltage surge, SWR was moderate but protected by APC circuit. Totally dead now.
Hi Jack, (No Pun Intended)
As this is such a fine radio, I would take it to the radio doctor for a once over check-up, The technician will find the problem and give you an estimate of cost to repair the fault, Take care of you radio, it's a great unit that should give you many more years of service.
I hope this advice is of help to you.
Cheers,
Peter
Dec 02, 2012 | ICOM Informatique BP-84SM,...
Can the Microphone be replaced on a ICOM M302 Radio
The MIC is available with the cord from Icom or me (847-746-0100) It is not easy for the novice, it must be routed through the front panel and plugged in to the circuit board inside. Not impossible to do, just tedious. Also, my wild guess is about $50 to buy the mic, so, not worth it if you pay labor!
Jan 09, 2010 | Icom IC-M302 VHF Marine Radio
ICOM W2a Won't power up, after full charge with two different batteries
There's a comment on eham.net about charging the internal battery first.
Maybe this will help you.
http://www.eham.net/forums/ModsAndRepairs/1961
Jan 10, 2008 | ICOM Informatique BP-85S,...
Radio Communications Logo
14 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
