Question about Bosch Washing Machines
Error f 46 on siemens washing machine s 16-46
Machine not start and the display show error f 46 on siemens washing machine s 16-46
fanny
  • 146 Answers
SOURCE: Error message
Switch machine off at the wall and leave off for 20 secs. Open the door. Switch back on again and close door firmly, giving the door handle an extra hard push. Should be o.k.
Posted on Nov 04, 2007
  • 84 Answers
SOURCE: unlock washing machine siemens wd 5125
hold the buttun down for three seconds
Posted on Mar 30, 2010
  • 174 Answers
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Posted on Jul 24, 2010
kapishtech
  • 2272 Answers
SOURCE: Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 11, 2010
SOURCE: bosch washing machine error code
what does F'18 means?
Posted on Mar 06, 2011
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
My siemens washing machine model no E10-46 is showing blinking key and door can't lock nor machine working so what can i do ?
it would tell me to call a repairman unless OLD then I would look for a new or slightly used one .
May 22, 2015 | Siemens Washing Machines
Error 27 on a siemens washing machine s16 39
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3459-siemens-wff2000-washing-machine-fault-codes.html
Jul 21, 2014 | Washing Machines
All lights lit up with the number 46 on timer
Hi Juan Abrante,
I understand that you are getting all the lights lit up with the number 46 showing on the display. What this can be is an error code. Error 46 means that it could either mean that the different control boards are miscommunicating or something is wrong with the main control board itself. Try resetting the washer for at least 3 minutes by either unplugging the appliance or cutting the power at the circuit breaker. When you do this, leave the power cut for at least 3 minutes. Bring the power back to the appliance and try starting it back up. If you are still receiving that 46 on the display, I would recommend getting a hold of the manufacturer for more help.
-Best of Luck-
Jan 03, 2014 | Frigidaire ATF6000ES Front Load Washer
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
Comes up on readout the pump blocked cant find type siemens washing machine(S 16-74)
This video will show you how to check the pump and we have other videos on how to change the washing machine pump if it needs replacing
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Siemens Washing Machines
Washing Machines Logo
26 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
