Question about Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Drain pump runs.
Drain pump stops.
Water is heard entering the appliance.
Posted on Jan 21, 2017
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing
Posted on Jul 09, 2013
3 Suggested Answers
pappapumpdaf
  • 635 Answers
SOURCE: red tap symbol lights up but no water comes in to
I hate to point out obvious things, but did you crank your line tap all the way out clockwise? And if you are using a line tap, are you sure the piercing needle conpletely punched through the hose?
Try removing the water line from your dishwasher and opening the valve to verify water flow.
Posted on Mar 11, 2010
taran_2005
  • 10515 Answers
SOURCE: "my Siemens dishwasher model se54m355eu
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
If you can feel water travelling through the water inlet pipe that means the machine, when first switched on must be doing the following.
Drain pump runs.
Drain pump stops.
Is this correct?
If not, is the drain pump running continuously while it is taking in water?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
We have a Siemens dishwasherSN66T091GB. The unit is not showing a fault code but the 'tap' light and 'rinse aid' lights are flashing continuously.
Rinse Aid symbol light indicates low on rinse additive.
Hope this helps?
Oct 16, 2016 | Siemens Dishwashers
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
Red tap symbol lights up but no water comes in to dishwasher
Mar 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Siemens dishwasher
My siemense dishwasher (2 month old) stopped working
No matter which program I choose, after 1 min the program stops and I get "tap" symbol on the led display.
Instructions says it might be a problem with the water source but i checked and it is fine.
ideas?
Aug 17, 2008 | Siemens 24 in. SE25T250 Free-Standing...
Help with how to use properly a dishwahser.
You either have a blocked drain or pump or check to see if the water tap is turned on. It means that either the water wont pump out or fill with water. Good luck
Sep 27, 2007 | Miele Advanta G2020 Dishwasher
Dishwashers Logo
1,081 people viewed this question
Top Dishwashers Experts
