Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Water leaking from dispenser into refigerator/French door bottom freezer
When we use the water dispenser located on the outside of the left refrigerator door, it is leaking into the right side under the produce door. We noticed it when it started to drip and part of it was frozen. We unplugged the frig, let it totally defrost, thinking maybe the dispenser was frozen in the door. After we replugged it 24 hrs. later, it still is leaking. Unlike all the reviews I have read, I love this refrigerator,. but would like to remedy the situation myself. Could it be the tubes in the back? Where is the water coming from? I did change the filter recently. Could that have anything to do with it?
  • 1 more comment
  • janlp0515 Sep 30, 2007
    We have the same question. We still haven't fixed it yet.
    We did try to make sure all the little tubes were pushed in wherever they are attached. If you don't use the water, it doesn't leak or freeze. What fun is that?
    Let me know if you resolve this.
  • Anonymous May 23, 2009
    i DICOVERED THE SAME PROBLEM WITH MY fRIDGE AS WELL. The Leak is coming from the water tank located behind the vegetable bin. I removed the Blue small clams, unscrewed the tank. Pluged one end and blew air into the tank and it seem the end closest to the side of the fridge has a leak when I did a pressure test on the tank. I ordered a new tank from Sears $49.99 to fix the problem It seemm that the pipe was glued & compressed into the hole and the pressure has caused it to leak. I love my Fridge but since I have had it I have experienced notthing but head aches. Fortunaley LG has refunded my money for what I apid for it & allowd me to keep the fridge as they had no way to dispose of it. My GE is problem free so far, but I still prefer the look of the LG/
  • Anonymous Mar 22, 2014
    Drip pan is fine
Yes after removing the clips just pull the hose off. The holding tank is a joke the new model I purchased doesnt even have the same part number as teh defective part. MAybe LG already knows this but soe not want to fess up they have a problem.
Posted on May 23, 2009
I have the same problem. I noticed that the holding tank is full of water and ice. Is this normal. Also any idea how to remove the "L" shaped connectors from the holding tank? There is a blue "U" shaped clip that I removed but do you just pull the connector from the hose after that?
Posted on Sep 30, 2007
  • 63 Answers
IT IS PROBERLY THE HOLDING TANK / TUBES LEAKING TAKE LOWER CRISPERS OUT AND CHECK THERE ITS BEHIND THEM
Posted on Aug 30, 2007
SOURCE:
Why would ice from the front door have an off taste but the ice in tray in the bottom freezer tastes fine?
I don't see from the literature that this model dispense ICE from the "front door." The dispenser on the left door seems only to dispense water. In your configuration the water comes through a completely closed system until it reaches your glass and should therefore not have an order or taste different from that of your cubes in the bottom Freezer.
Nov 25, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
Why is water leaking at the bottom in front refigerators
Water leaking in the freezer and on the floor in the front of your refrigerator usually is caused by a blocked evaporator drain line.
Hope the video helps you understand what you will need to do to fix the problem.
Appliance 911 Sea Breeze
Leaking Refrigerators
Sep 29, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Late model freezer below maytag refigerator leaking water out the bottom where is the drain located?
drain is in the back behind the plate . and below the evap coil . if its covered with ice you cannot see it .. mm
Aug 06, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Water on the floor on the left side of the refigerator
possible water line couplin leak located under left front of refrig behind grill or cracked line.
Mar 01, 2010 | Kenmore 53642 / 53644 Side by Side...
Remove Faceplate on fridge
I am have the very same problem. I removed the dish beneath the water/ice dispenser, and located two small screws. These two screws appear to hold the bottom of the face plate to the door. I removed them. However, the faceplate still did not come loose. I suspect there are more screws or clips toward the top.
Nov 20, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
Refigerator is freezing food
Hi, this problem is going to be with the running thermostat. It has gone bad and stays open which in turn will keep the compressor running continually. It can normally be located in the control panel inside the fridge. Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Maytag Ice20 not dispensing water
Hi!!! make sure that your water reservoir is not frozen located inside the frig section on the way back. If not the you have a bad water valve located in the back of the frig on the bottom..Good luck..
Dec 31, 2008 | Maytag MFD2560HES Bottom Freezer French...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
395 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
