Question about Mitsubishi Car Audio & Video
TV 5760 W remote controller
I need to buy the remote cobntroller for this product: CAR COLOR TV TV 5760W WIDE /RGB
SOURCE: i need a new remote control for hisense tv flat panel, where can i buy one?
I've had very good with the Radio Shack Universal Remote. It recognized everything I had. Try that, because if it doesn't work, you can take it back for a refund.
Posted on May 07, 2008
  • 2336 Answers
SOURCE: need remote for 2006 sanyo color flat screen tv
Great info AlmostBob.
Posted on Jul 05, 2008
  • 9 Answers
SOURCE: Need a replacement remote control for an old TV
I found one and bought it. Thanks
Posted on Sep 11, 2008
ramon49
  • 111 Answers
SOURCE: EEP RESET changed my picture to wide screen.
Go into Menu and look for Video section and find wide,panorama,16x9 and 4x3. gottas be there. then click on normal thnen click on what you want..
Please rate!!
Posted on Mar 16, 2009
SOURCE: 3 Digit Product Code for Magnavox tv RR1337 W101 (13S401-00AA)
0807 works with a Philips Universal Remote on my Magnavox RR1337 101
Posted on Jul 04, 2009
Hello, we just received this tv from a friend without the remote series 4 energy efficient and wide color enhancer keeps popping up what do we do
You buy a new remote for it because not all functions are available from the television. Having said that, scroll through Menu and Picture and look for a Colour Enhancer Control and toggle it off.
http://www.ebay.com/sch/Remote-Controls-/61312/i.html?_nkw=Samsung+LN32C450
Samsung LN32C450
Apr 01, 2016 | Samsung LN32C450 32 in TV
How do I get my color back and closed caption off my TV. I have my Phillips Magnavox TV serial number TS2544c122/ The remote to controled with our dishnet one. I need to get my color back and closed
Sounds like you might have switched display from pal to NTSC or vice versa.this is usually the first thing that causes color to drop out.if not you will need to go through menu settings to check if you have rgb or similar color controls that are not set correctly.i assume you have already checked the saturation has not been turned down.sometimes the remote buttons can stick down or be under a book or cushion which will alter tv controls without your input.
Jan 03, 2015 | Televison & Video
The color adjustment won't work. I click on it and go down on other adjustments but none will open to adjust the colors.
you can buy a universal remote for 1 dollar.. option 1 however if you are using componelt input as in RGB then you have no control over your colors
Oct 07, 2014 | RCA P52927 52" Rear Projection TV
How do I make my vizio screen full?
Hello
If you are using RGB mode, make sure that H size and V position in the On Screen Display [OSD] are set correctly.
If you are using TV, AV-C, AV-S or Component with 480i input, use the WIDE button on the remote control to scroll through various screen modes. OK.
Dec 18, 2011 | Vizio L37 Television
I HAVE SINGER TV MODEL:SCT21M63STC.WIDE OFF FUCTION IS NOT WORKING FROM REMOTE,IF THERE IS WIDE OFF FUCTION REMOVEL IN REMOTE THEN PLEASE TELL ME.
if the problem appears to be only in your remote control for wide off button, and other button function seems not affected... i suggest that u clean the remote control inside, of course you need to disassemble it and clean the rubber pad. esp. the wide off button. it happens when the carbon contact was cover w/ dirt...last sol. is to buy a new "same" remote...
Feb 11, 2011 | Televison & Video
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
TRYING TO INPUT LAPTOP TO RGB IN,AUDIO WORKS BUT VISUALY "NO SIGNAL"
Reading the online manual - You should have the laptop connected by VGA - PC input
VGA Connection you need to select the correct input on the TV
  • Select the RGB-PC input source on the TV using the INPUT button on the remote control.
you will need to set the laptop up to output to the VGA output, to do this - varies by different manufacturers - But often F4 or F5, with the FN key selects the VGA output - have a look at the F keys across the top of the machine and see if you can see a picture of a screen - then use the FN and that F key together to toggle between display it will change to <Laptop Screen Only><Laptop screen and VGA output><VGA output only> not necessarily in that order.
This is the support site for that TV http://www.lg.com/us/support/product/support-product.jsp
direct link to the PDF user manual http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=37LG30&matchedModelCode=1000003995&searchEngineModelCode=37LG30&initialTab=documents&targetPage=support-product-profile#
Mar 31, 2010 | LG 37LG30 37 in. LCD HDTV
Help with Hitachi Audio Video Center (AVC80U)
okay so it doesn't need a remote control.............. The AVC08U should register immediately with the tv, the box itself has a bad HDMI out.
Dec 07, 2009 | Televison & Video
No green color in picture?
its a simple fix. just go to your menu in TV adjust the RGB color. balance the RGB settings.
May 26, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Car Audio & Video Logo
65 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
