Https://www.hyundaitechinfo.com/index.asp Make a free account and it has everything about the vehicle. It is used by dealers to repair those makes. It takes some getting used to though.
Hello! The Brake Light Switch is the likely culprit...Check fuse # 8 (10A) Dash fuse box first...On the Brake Switch connector; The Pink/Black wire should have 12 volts when brake is depressed...If it does the second choice is the Shift Lock Solenoid isn't pulling...Lets check the first choice and eliminate it before moving to the next...Send a comment...Guru...saailer
hello, if these are sort like nissian sentry, they have a switch , when you put foot on brake you can put it in gear, if myou dont put foot on brake the shiftr will not move, check and see if you have a safety switch on the gear shifter, you can call auto part, or dealer they would tell you..
Sign up for an account on hmaservice.com. Once you do so, log in and click on "Shop". You can then enter your year/make/model and you will find the info under, engine mech. system>timing system>timing belt>repair procedures. Very detailed, and best of all, FREE.
If your transmission fluid level is okay, then you need a new speedometer cable. Its not terribly difficult to replace, but it does require you to pull the instrument cluster. A local Hyundai dealership might be willing to photocopy the specific speedometer cable replacement instructions out of the 2004 Accent shop manual.
