Question about Sharp LC-32SH20U 32 in. LCD HDTV
No video with the vga cable
I connected my vga cable from computer to tv. I have sound but no video. i run windows 7. is this tv not compatible with this operating system? and if it is, how do i get the picture to work
    Master:
  • 663 Answers
Have you installed the driver of your TV into your computer? Check if it has a driver dvd or cd. You can also try scanning your computer with radarsync to make sure that the drivers (video driver) are up-to-date.
David
Posted on Jul 18, 2013
2 Suggested Answers
  • 1015 Answers
SOURCE: I have a Sharp LCD TV and a Toshiba Satelite
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Posted on Jan 09, 2010
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
I just want to know what kind of cable I need to connect my LTV-37w2HD TV to my computer?@highes.net
The video cable should be a VGA cable, assuming your computer has a VGA connector. Get one that has M/M ends. This is sometimes listed as a 15 pin D-sub connection. Then connect a 3.5 mm audio patch cord (m/m) between the audio out (speaker/headphone) pf the computer to the TV's VGA audio in (if you want to use the TV speakers).
If your computer has an HDMI or DVI output, I do not believe that you can connect to the TVs HDMI port. (The signal from the computer is not the same as that from a set top box.) If you have a DVI port, get a DVI to VGA adapter and then connect to the VGA cable. (You could use a DVI-DVI cable and then the DVI to VGA adapter at the TV. However, space is an issue at the TV.)
Make sure that the VGA port is enabled on the computer. (Some newer computers have a different video port enabled initially.) This may require entering your BIOS just after turning on the computer. Usually you need to strike Esc, F1 or F2 repeatedly starting when you press the power button. (F10 is also a BIOS access with some manufacturers - the key will be listed in a splash screen that is only visible for a few seconds.)
With the computer and the TV off, connect the cables. Then turn on the TV and set the input to VGA. Next turn on the computer. (If this is the only monitor attached, the computer should find the correct resolution (Windows). If you are using a dual monitor option, then you may have to enable the TV as a monitor. This will depend on the OS. For my Windows 7 laptop, it's right click on the desktop and choose Graphics Properties. Set the monitor options for both, external or attached and click Apply. Then click OK when a confirmation window appears. With my Windows 7 desktop, it's right click on the desktop and choose Screen Resolution. Similarly choose the settings, click Apply then OK to confirm.)
I hope this helps.
Jun 02, 2011 | Westinghouse LTV-37w2 HDTV
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
How do I get my GT5428 to connect with my TV to access Netflix?
You must be a NetFlix subscriber.
1.Then click on this link http://www.microsoft.com/windows/windows-media-center/netflix.aspx to download NetFlix for Windows Media Center.
2. Open the Windows Media Center
3. Click on Task
4. Click on General
5. Click on Automatic Download Option
6. Configure the time
7. Click on Download Now, to download the latest guide listing
8. You can now select on the videos you like to view.
Mar 01, 2011 | Gateway GT5428 PC Desktop
How to connect tv cable on my laptop
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable . It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Nov 13, 2010 | Lenovo IdeaPad Y510 Notebook
How could i connect this tv to laptop
Connect by this way:
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
Sep 16, 2010 | Samsung CW29M64NS 29" TV
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
Conecting laptop to tv
1. S-Video ? This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You?ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC?s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work. 2. VGA ? If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won?t find a VGA port on regular TV?s though, so this option is if you have an HDTV. 3. DVI - DVI stands for Digital Visual Interface with ?digital? being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80. 4. HDMI ? Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI. 5. Scan Converter Box ? This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Apr 07, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
Connecting PC to TV
Most tv's are not compatible in this matter. They were made to be a tv, and not a computer monitor. Some of the newer tv's are compatible. If they have a vga port then they are compatible, but may not support or have the resolution expected. The vga to s-video cables were designed mainly for the use of the newer computers with vga ports to older flat panel monitors with s-video ports, at the time that vga was first coming out. This cable is on the verge of obsolete. So, I don't believe that you're going to be able to hook the two together, and get the outcome you want.
Jul 26, 2008 | Computers & Internet
Sharp LC-32SH20U 32 in. LCD HDTV Logo
381 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
