Question about Konica Minolta Office Equipment & Supplies
Remove white background - Konica Minolta Office Equipment & Supplies
"Konica Minolta C352 - cyan and white pattern background on every print?!
What are you printing a Word document when this happens ?
suspect pattern may be in the software you are printing from.
Go to software help screen and look search for removing background pattern or removing watermark.
Apr 11, 2014 | Konica Minolta Bizhub C352 Digital Copier
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
Aug 30, 2013 | Computers & Internet
I find the white background too bright. Can this be changed? Can the white background be altered to a less intense color?
there will be setting in monitor LOT.....try this to change the white background ......in LOT there will be focus adjusting will be there
Sep 24, 2010 | Computers & Internet
Screen is white when on.....
Try disconnecting your connection to your computer.
If you see a no signal message with a dark background, you have problems with your video card.
If you continue to recv. the white screen, you have input signal problems with the LCD monitor itself.
If you do recv. a no signal message witha dark background, try removing and reseating the video card.
Oct 24, 2009 | ViewSonic VX2235wm LCD Monitor
Adobe photoshop
Hi. Just select the background of the necklace using "Magic Wand" tool in Photoshop, press delete, select "Paint Bucket" tool, select white background using the color picker, then pour white on the selected background.
Mar 16, 2009 | Adobe Photoshop 7.0 for PC
Nokia 6288 Phone Cant Start
try to remove the battery and wait for 2 mins and then restart the phone if it doesn't work send it to nokia assuming it has a valid warranty!
Oct 28, 2008 | Nokia 6288 Cellular Phone
How to set default white background in Microsoft Windows 98SE?
go into control panel, display settings and hit 'dafault', should return you to a generic screen. seems like an old model check monitor plugs and video card.
Jun 21, 2008 | Microsoft Windows 98 for PC
Scanning problems
R 105 from my HP 5370 has burnt out. Replaced it with a 30E but it becomes very hot in a few seconds.
Read somewhere to remove C118, is this the besst solution?
Thanks in advance for answering.
Jun 01, 2008 | HP ScanJet 5370C Flatbed Scanner
Screen background colour
Its an LCD problem. if you have the means to take the phone apart, carefully remove the LCD assembly and clean its contacts and the circuit board pads. If its still the same, only a replacement can solve it.
Apr 07, 2008 | Nokia 1100
Gifs with white backgrounds
1. open in Photoshop
2. Windows --> layer. Then double click the layer there, click OK the dialog box so that the "background" become "layer"
3. Select the white background. You can use magicwand tool, or if the object you want to keep is not white, you can use "select color--> white"
4. Edit --> clear.
5. safe as gif
Feb 03, 2008 | Adobe Photoshop imageready 5.5 for PC
300 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
