Question about Jaguar MCE6605 Air Conditioner
Vax carpet cleaner
I need a manual for a vax carpet shampoo - the round orange one? Can I find one to download on line anywhere.
  • Anonymous Oct 06, 2008
    dont know how it works
Sounds like you have the 6131 model, in which case you can download the manuals and self help videos on the UK VAX website www.vax.co.uk
Posted on Nov 30, 2007
The UK VAX website has manuals in PDF format you can download and self help videos
    Novelist:
  • 75 Answers
Hi, Looks like your model # got you into the Air Cond area of FixYa. I did however look into it and found a place that could help you with the right mod # http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=24953 The home page is http://www.dirtdevil.com/default.aspx Looks like they want $4 though. Hope this helps. kstfas
Posted on Aug 27, 2007
How can I download user manual for Vax 2000 wet and dry carpet cleaner ?
Try Googling (vax)(2000)(manual) without parens.
Jun 17, 2017 | Vax Vacuums
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
How do I gat fluff out of shampoo cleaner
Don't use a shampoo cleaner. All soap is a Lubricant so instead of using a Shampoo try IVORY soap or Irish spring Or that HUGE old school bar of soap its Light GREEN & used to help poison ivy =you may have to soak the Bar of soap over night but a water softner keeps soap from creating bubbles & a water softner is only salt added to water so add a table spoon to 1 gallon to IVORY or DOVE or IRISH SPRING it cant hurt its only soap
Jul 26, 2014 | W87-Rh-P Rapide Ultimate Clean Upright...
I have lost manual could you please showfor vax rapide spruce carpet cleaner
Ok, go to www.vax.co.uk and when you bring up their web site, click on the large Support box at the top, this will lead you right to how to download a manual. I just did it, it was easy. You can type in the model no. or click on the carpet cleaner photo and it will easily lead you to the manual. take care and good luck, Andy
Mar 09, 2011 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Jun 01, 2008 | VAX Appliances Vacuums
Heating & Cooling Logo
997 people viewed this question
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
