Question about Toshiba D-R5 DVD Recorder
DVD PROBLEM does not want to spin.
  • lamesauce Jul 09, 2008
    I can tell that it is having trouble spinning because I've looked at it. The dvd does not spin and it makes all sorts of weird sounds. Mostly it sounds like gears trying to turn but every now and then there have been odd beeps. I've cleaned the area of dust with an "air can" and left it unplugged for up to an hour waiting for it to cool off. Neither things worked.
  • Henry  Thomas
    Henry Thomas May 10, 2013
    if your dvd is not spinning usually the display has on no disc that means the set is getting power into the circuit.however i can recond that the tray can open and close so i will take it that your led motor and try motor are fine and working.i point your problem to the spindle motor. this motor is between the two mention motor and is actually the .change this motor and your dvd will restore back to normal.
Sure it's not spinning? Unless you have the cover off it's hard to tell. The laser works opposite old record players, it reads from the middle out. If it does reach the middle it will not read. Usually says no disc. bulldog
Posted on Jun 21, 2008
SOURCE:
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
Disney D7500PDD Portable DVD Player doesnt spin DVD
Very Good Daniel,
if you are good with a srewdriver.. you could use a DVD from a computer and swap it to disney
Does the door to DVD slides out or pop the lid.
You still can swap if you are careful and you know what you are doing
I've done a few times.
Let me know in the future, if you can't, you can send to me for repair
Jul 25, 2010 | Disney D7500PDD Portable DVD Player
DVD ejects itself shortly after inserting
If you have tried cleaning the laser lens and the unit does spin,You have a defective laser assy,this is common with these players.If unit does not spin,try spinning it when you insert a disc by hand as this may start the unit spinning,if starts spinning then unit has a bad spin motor.
Apr 13, 2010 | Philips Televison & Video
Dvd player not reading new DVD
probably needs a new belt they do wear out and loosen up over time
Feb 16, 2010 | Philips DVP1013/37 DVD Player
Dvd wont play just spins
Usual suspects (I have seen each one of these):
1. Home-made DVD defective
a- bad blank
b- bad burn (software settings incorrect)
c- not finalized
d- bad DVD recorder
2. Commercial DVDs - very scratched near center hole where startup data lives
3. Dirty laser lens on DVD player
4. Bad circuitry in DVD player (repairs almost always cost more than a new player)
Jun 24, 2009 | Daewoo DV-6T834 DVD Player/VCR
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
Panisonic DVD RV-31 Wont read any DVD...shows a "Ho2" code
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VERY CAREFUL NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knackered and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jan 10, 2009 | Panasonic DVD-RV31 DVD Player
Wont spin
cdfreeze, DVD drives spin up the platter and attempt to read from it. If the read fails, they stop spinning the drive. So, I think the problem you have is that the device won't read. DVD drives have some very small plastic pieces that can break and cause failure. They also have a read head that can get out of alignment. If you're ambitious, look at the drive and see if you can find any other damage. Don't run the drive open, though, because there is invisible laser that can blind you (there should have been a warning on the top of the drive when you opened it). I checked eBay and this DVD player sells for under $20 (including shipping), so don't spend too much time on it. Definitely let me know if you have questions or comments.
Aug 22, 2007 | Philips Magnavox DVD Player MWD200F
Toshiba D-R5 DVD Recorder Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
