Question about GE WJSR2070B Top Load Washer
Kenmore washing machine old model
My washing machine wont spend and i cant get any hot water
  • 291 Answers
Depends on how old.. but first Check lid swith for not spinning.. No hot water take hose off make sure you getting hot water to the washer... if water to washer.. water valve probley bad
Posted on Aug 27, 2007
  • Mike Johnson
    Mike Johnson Aug 27, 2007
    oops.... lid switch
Hi I have a problem with my Kenmore washing machine,in particular I can not use hot water anymore. When I use my washing machine hot water does not stop at set water filling level (law, medium,high)...
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
Mar 11, 2011 | Kenmore Washing Machines
I have a Kenmore/Whirlpool Washing machine model 110.26832691 that doesn't allow hot water into the tub. I have put a new timer as well as a new temperature switch. Any answer?
Hello
Please try to swap both the connections, hot to cold and cold to hot, swapping will hopefully work. If swapping wont work then the water inlet valve also known as inlet hose assembly is bad and needs replacement. Please check the water level switch as well although I believe it is the water inlet valve causing this problem.
Kevin
Nov 11, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
KENMORE 22442100 WONT FILL UP WITH UP WATER
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 23, 2010 | Kenmore 22422 Top Load Washer
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
My washing machine wont stop filling with water
sounds like the hot cold water valve is bad,you also have the water level switch,the switch has a water level hose on it,some times the hose comes loose,chech y=that also,let me know what you find-mike
Mar 17, 2009 | Kenmore Washing Machines
Wont fill with hot water
3 things to check.. Make sure that you are getting hot water upply. Check your water inlet valve. IF both are ok then check the switch to make sure that it is sending power to the water inlet valve to let it open. These parts can be found behind the knobs after you remove the cover
Feb 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
GE WJSR2070B Top Load Washer Logo
42 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
