Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Side by side Kenmore refrigerator
Whenever the water stops there is a "banging sound from the rear of the refrigerator. how can this noise be eliminated? It doe this when filling a glass or when making ice.
  • 291 Answers
Sounds like maybe your water valve for icemaker and door water may be loose take back cover off bottom ref... check out w. valve
Posted on Aug 27, 2007
SOURCE:
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
Apr 04, 2018 | Kenmore Washing Machines
Viking side by side refrigerator noise
sounds like your fridge is not hooked up to water or water off
the sound is the water valve calling for water if no water is hooked up or supplied the valve is quite noisy
turn water on or lift icemaker arm to up lock position to turn ice maker off
Mar 04, 2017 | Viking VCSB423 Side by Side Refrigerator
When water is flowing to door dispenser or ice maker the fridge makes a loud banging noise. Sounds like water hammer - maybe a valve is malfunctioning? What/where should i look for the problem?
Sounds like your water has been off for maintenance. This will make a sound like this but the rest of the faucets would have done it also when you first ran water through them the first time. So if you have a filter on your fridge, remove it and re prime before putting back on. If not, look at the back, bottom where the water supply connects to the back. Have some one try to get water in the door while you hold your hand on the valve where the water supply connects. See if it vibrates and makes the noise. Also follow the line and see if you have two different water valves. If so do the same with it. One should be making the noise if your filter does not have air in it. Good luck.
Dec 21, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Noisy Kenmore Fridge
remove rear panel. make sure compressor is not loose. is noise inside refrigerator or outside at bottom rear?
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loud noises, bangs and sounds like water falling
if it’s a banging sound--- I know one of the noises the system 2000 will make is a bang or rattle at the end of the run cycle, which we call "shudder stop". If this is your noise then I have to give you some bad news here. Sorry....... The only way of repairing this is by having your compressor replaced as it has to do with an internal problem in the compressor itself. There may be a silver lining, though, if you are the original purchaser and you have the receipt. Some of these systems came with a 10 year warranty on the compressor, so you might want to check this out.good luck
Dec 10, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kenmore side by side model # 106.53542300
there are 2 fan's in the uint one is located by the compressor itself, and the second is loacted in freezer compartment behind hte back wall, it is possible and fairly common that the bearing on one or the other has gone bad causing your noise issue. if it soulnds as if hte noise is coming from the compressor itself, then your out of luck no repairing that item just a replacement and problalby not worth the cost
Oct 29, 2008 | Kenmore 53542 / 53544 Side by Side...
My kenmore refrigerator kept running.
from your description it sounds like your hearing the start relay trying to start your compressor. most likely this relay is bad and needs replacing.
Dec 18, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
