Compressor is making a noise on and off
If its the compressor, the compressor is bad and needs to be replaced, typically when they do that, they will short out, and trip the breaker.
It could be the condenser fan motor going bad too, knocking/pinging noise seems more suspect to a fan motor going out or a bent fan blade.
Recommend a appliance repairman to look at this
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
SOURCE: Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
SOURCE: Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
SOURCE: refrigerator knocking noise
the motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
SOURCE: funny fridge noise, kenmore elite trio
I have a Kenmore Elite Trio and the freezer was making a
frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is
opened. It will stop again when the
freezer drawer is open and the light switch is pressed to turn off the
light. The ice drawer was full but it
had stopped making ice.
Here is the fix in less than 10 minutes using only a
screwdriver.
