Question about Panasonic Lumix DMC-F7 Digital Camera
Charging Problem Charging appears complete after about 15 minutes. Normal charging time is 90 minutes. When the camera is turned on the oblong battery level indicator is filled white where previously it contained diagonal markings. The white disappears rapidly as the battery discharges within just a few minutes. Enough time to take a couple of picture. The camera then shuts down. I sent the camera to a repair company who at first said they could repair it. Later they told me the camera was "beyond economical repair." The camera worked normally when plugged into the mains supply.
  • Stephen Bowles Sep 10, 2007
    Sorry it has taken me so long to post this. I have been so busy with college work lately and just did not get around to checking for answers.
    There are no non-rechargeable batteries available but an external charger can be bought at very little cost. I shall buy one as the camera works well otherwise.
    Thanks. Your help has been much appreciated.
    Sincere thanks to valiis. Your help has been much appreciated.
I CAN T CHANGE MENU IT IS ONLY IN DEL MENU
Posted on Aug 23, 2009
    Scholar:
  • 72 Answers
Sounds like the circuitry that controls the charging of the battery has gotten damaged. You can try using regular non-rechargeable batteries if the camera can use them. Otherwise you will have to find another way to charge the batterys, if you can find an external charger for the batteries that should work too. Hope this helps.
Posted on Aug 26, 2007
Digital camera batteries go bad?
Yes the can go bad.
I still have 9 year old Kodak lithium batteries in good condition, nut I know sometimes my rechargeable batteries last no longer then a year. It is a shame that some camera brands only give a 90 day warranty on the batteries.
To keep your rechargeable batteries in a good condition, give them a charge at least every 3 months. Or always a day before you need the camera. Never try to use speed chargers. I still have a charger capable of charging full within 15 minutes. The barrettes are hot, and when charged that way after 10 or 20 times they are dead.
Just use the charger that came with your camera.
But if you only can shoot a few shote with your battery, buy a new battery.
Jul 12, 2014 | Kodak EasyShare Cameras
Camera wont turn on after charging the battery
Bruce, you didn't provide a lot of information but I can tell you that the few times this has ever happened on my Nikon D-90, the battery did not charge, would not charge and I had to throw it away, or it was a charger problem.
I've had it happen when I tried to charge it on my corded Nikon Charger and I never got a charging complete indication after charging over night. When I put it in the camera, the camera indicated it was not charged even though the charger indicated it was charging. But, when I put it on a travel charger, it charged in about an hour and worked fine. The next time I put it on the Nikon charger, it worked fine.
I suggest you verify that the battery is good and charged or capable of charging. If it is, then check to make sure the battery contacts are clean both on the battery and in the camera.
If the contacts are clean and you're sure the battery is good and charged, I'd say the next step is to contact Canon. I've heard their customer service is very good.
May 20, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
Heating problems of set
Pratap, it sounds me water damage problem,if you are not Technitian dont try this please.give some oficial repairer.this is a hardware problem and probably problem is with PA Network IC or/and Avilma, 1.First clean board with Alcool2. after this let it dry completely then apply paste in ICs and rehot to 310 to 375c up to 12min with Hot air gun, make sure ic's and board's doesnt move on the place during process.3. after this leave board to 15 min for come to normal temperature.4. then try to charge and use to check if solved (90% of cases it solved) other 10% possibility of camera flat cable damaged cause the same problem. so Best Of Luck.
Jun 29, 2012 | Sony Ericsson K850i Mobile Phone
Charging light oepration
Absolutely. It blinks orange (or red) while it is charging. It will glow steady orange when the charge reaches 90% and green when fully charged.
May 20, 2012 | Canon Cameras
Pwoer shot G5 red light blinks while charging
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
May 11, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Panasonic Lumix DMC-F7 Digital Camera Logo
67 people viewed this question
Top Panasonic Cameras Experts
Jay Plesset
cesarakg
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
