My TV is dead since I did not use it, I am looking if I can get a new circuit board for this tv.
Comments:
Aug 28, 2007
- Thanks for the reply but I had given my friend to repair which he tried to repair, he was looking out for a part which he could not find, will I get a new circuit board for this set,
The SONY 2162 is a Old Warhorse. It was manufactured nearly 20 years ago. If the set is dead, and if no one has tampered with it, it can be repaired. One problem I found often in the 2162is that it's mains ON OFF switch failed regularly. check that.If you have knowledge of Solid State Electronics, please carefully open the Back Cover and first check the fuses. If they are ok, then check the SMPS switching transistor. If it is short circuited, then replace. Also check the Horizontal Output Transistor at the same time.
tv was running like normal and suddently the screen went blue and a red lock showed up. How can i...
(More)
tv was running like normal and suddently the screen went blue and a red lock showed up. How can i remove the lock and get the tv running again?
my sharp tv has been reset after using my universal remote now i only have 12 channels help me...
(More)
my sharp tv has been reset after using my universal remote now i only have 12 channels help me change it back to catv. . .tnx
Bought a 27 in. Sansui STHD tv hooked it to my cable & box programed tv code so i could...
(More)
Bought a 27 in. Sansui STHD tv hooked it to my cable & box programed tv code so i could adjust volume & channels.When i turn tv on it displays analog for a few seconds on screen then blinks off. Instructions for digital not clear and i cannot get channels when i tried to switch over.should i leave it on analog setting so i can get channels & see a picture?
