Question about Kenmore 74822 / 74824 Top Freezer Refrigerator
Kenmore 58395 When you press the water dispenser on the front, water spews everywhere. Any suggestions on what the problem might be?
  • 63 Answers
LOOK AT THE END OF THE HOSE WHERE THE WATER FLOWS OUT CHECK FOR A BLOCKAGE MOLD ETC... IT MIGHT BE TOO THAT THERE IS AIR IN THE HOLDING TANK KEEP FILLING GLASSES TO CLEAR LINES
Posted on Aug 30, 2007
SOURCE:
What causes ice makers to spray water all over freezer?
Sometimes the water chute that puts the water into the dispenser is too long and it hits the panel and it sprays everywhere.Just cut it a little shorter.
Apr 16, 2015 | Kenmore Refrigerators
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
My washer is now spewing water out of the little drawer thingy that you put the wash powder in. Leaked water all over the floor! I know nothing and I do mean nothing about front loads, so help me...
the detergent dispensers on front loads many of them are made to release a little water after the wash process to clean out the dispenser and drain excess liquids. however u may have a damaged water hose line connecting to it or some kind of shut release valve on it that may be defective , u have to pull out and look at the dispenser more closely
Mar 23, 2015 | Washing Machines
Water spewing everywhere pressure cooker
Happen to me cooking porridge when the mixture within the pressure cooker is too thick such that not enough steam is produced at ounce to get the cooker to seal itself. Add water if possible.
Jul 29, 2012 | Fagor 8 quart Duo Pressure Cooker
Kenmore He 3 model 11042832200 water leaking from the dispenser and draining down the outside of the washer. Water drains into washer fine when the dispenser cup is not in place, so there doesn't...
If you take the top off, you can see the whole part called the dispenser, https://www.searspartsdirect.com/model-number/11042832200/0583/0153200.html
Check all the hoses etc. Yes you can even run the machine with the top off and see where the leak is. To take the top off there are three screws in the back at the top and when you remove those, the whole top lifts a slides back and comes off.
Oct 14, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water is leaking from the Ice maker on top of the
the water valve on the back of the fridge has malfunctioned.
Jul 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Front load duet washer is spewing water out of soap dispenser.
The water flow is restricted into the tub by an obstruction ie sock, lint.
Take the top off and the drawer out. The black hose underneath the dispenser that leads to the tub has something caught at the end. Pull the hose off where it enters the tub and examine, you will find the blockage there.
Mar 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is spewing water everywhere sometime during its cycle. The floor is soaked! It seems to be coming from the soap dispenser area. I cleaned the dispenser really well but still water everywhere.
The only way to determine where the problem lies is to take off as many covers as possible then run your usual wash cycle. The problem could be a leaking or blocked pipe or a rubber seal that leaks etc etc. Have somebody in the know open up your machine to determine where the leak comes from.
Best wishes,
Graemevm
Dec 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 74822 / 74824 Top Freezer Refrigerator Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
