Question about Singer 20U73
Needle hits? My needle keeps hitting the bobbin carriage housing and breaking? Realized the carriage was loose. Don't know how to set it's timing. It has 3 set screws and all were not tight.
  • Margie Campbell May 11, 2010
    Is there an online schematic for this machine? (SE 270D)
  • Anonymous Mar 17, 2014
    I need to know which way the screw should be turned as the instructions are v. vague. It is tightly turned which doesn't help. Thank you
  • 202 Answers
OK, this is a general timing procedure. Loosen the screws on the main shaft gear that goes to the hook drive gear and separate the gears. Next put the needle in the left position and bring the needle all the way down by turning the handwheel. As the needle comes up make the point of the hook enter the scarf of the needle (just above the needle eye)and hold it there while you put the gears back togeather and tighten the screws. This should put it close to being in time. To fine tune it you can loosen the needle bar screw (half way up the bar that holds the needle) and adjust theneedle so the hooks point is just above the needle eye. You may have to do this a few times in order to stop it from skipping stitches. Good luck. Rick
Posted on Aug 27, 2007
Needle hitting this and breaking. Pulling too ******* thread caught in bobbin case is the cause. How to fix or readjust?
breaking needles from hitting can be from several problems
1-- needle /hook timing is out
2--needle thread tension is too tight pulling needle side ways
thread caught around bobbin holder is top thread too loose
take it in for a service check as the needle /hook timing is complicated to adjust and the problem could be more complicated than suggested
Nov 23, 2016 | Sewing Machines
Needle hits and breaks, when I take bobin and carriage out the needle still hits. Ha ow can I adjust the timing? Brother CS 6000 i
Make sure you are using the correct needle for your machine! Also check your manual to make sure you are inserting it properly. Some needles are rounded on one side and flat on the other. If you use the incorrect needle it will hit or insert it incorrectly it will also hit and break. June
Jan 26, 2015 | Brother CS6000i Computerized Sewing...
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
I have an eXplore 220-240
Try to rotate the hand wheel towards yourself with the bobbin removed. If it still hits it is time to have it timed. Also, check carefully to make sure the hook (underneath bobbin) assembly is put together with the parts setting in their positions correctly and not cocked.
Jan 23, 2018 | Elna Sewing Machines
Needle hits the wheel under bobbin
Sounds like the toothed-belt (if there is one) jumped off timing. You can try realigning until the needle goes into the hole as the bobbin holder rotates in place. You can do this by manually slowly operating machine -- do not do with electric pedal.
Oct 08, 2012 | Singer CG590 Mechanical Sewing Machine
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
My needle keeps breaking. So I unthreaded everything and cleaned the bobbin area. Per the manual i rethreaded everything but when i get to the part of turning the balance when toward me until the needle...
check to make sure the needle is inserted correctly--flat side to the back of the machine
that the needle is inserted all the way up in the needle shaft
check the needle clamp screw to make sure it's not loose
is the needle correct for the fabric that's being sewn
check to make sure the needle is not hitting the needle plate- if it's hitting the needle plate or the bobbin case then it's possible the machine is out of time & would have to be serviced because they have the proper tools to time it
Aug 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Singer 20U73 Logo
322 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
