Hello. I have System trouble nr. 1 active and from manual I can read that trouble condition is "Service Required". As it is old system and I don't have any service provider to call, does somebody know what this trouble exactly means or how I remove it?
SOURCE: service message for alarm system
The message is trying telling you that the system has a fault and most likely the control module has disabled the system. After the problem is fixed the message will clear. You can have the system tested by Volvo to see what part of the system has a fault, most likely they will charge about 1 hour labor time.
SOURCE: Need service manual for Pioneer XV HTD5
http://www.service.pioneer-eur.com/peeservice/InstrManuals.nsf/0/817C627E26301ED841256BE300511FA3/$File/XRB3016_XV-HTD50.pdf
The manaula as asked
Good luck
Nic
RATE me pls:)
SOURCE: 939 service system board; what it's mean.
First, make sure the printer power is off and remove the RIP board.
When you turn the printer back on, the only option on the display will
be to perform the test. Pressing the button next to that begins the
test. The page that comes out should have just a lot of lines printed
on it. If this does not print or is somehow messed up, then the problem
must be with the engine board. If this page prints and looks OK, then
it is probably the RIP board that should be replaced. Please keep in
mind that this test cannot be considered to be conclusive but it can be
used to make an educated guess about which component is failing.
When
the printer beeps five times and the operator panel is blank, there are
several things that might cause this. It could be the op panel, the op
panel cable, the Low Voltage Power Supply (LVPS), or the engine board.
To find out which component is failing, the printer would need to be
checked out by a service technician and the failing component replaced
by him/her.
