Toys Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Little tykes 12v hummer needs new accelator switch
Where can i get the right switch - the number on burned out switch is 0429 and also ZL 03338395 - it has 3 prongs
Anonymous
Level 2:
  • Expert 161 Answers
  • Posted on Mar 28, 2009
Anonymous
Expert
Level 2:
Answers
161
Questions
Helped
54206
Points
324
I would take it to a radio shack to match it to another
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Apr 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
15180
Points
42
This Little tikes hummer switch is specific for the ride on toy.
I found it at this site http://www.shopjandl.com/mepu0001.html.
It seems to also be the same one for peg perego and power wheels as well.
I would also make sure the wires are clean too.
hope this helps
I need a 12v battery and charger for little tikes hummer 4931 h2 suv vus 612455300
Hi, You can try a 12v battery the one's for motorcycles. Go to auto parts store they may have one for you. Good luck.
1helpful
Directions for charging the Little tykes battery
mcdevito75 here, On average 6-- 8 hours, if battery is 2-3 years old you may need new battery. contact little tykes online or call them.
Jun 25, 2010 • Toys
1helpful
Little tykes hummer how to remove gearbox
You have to take off the push nuts, but you will have to replace them.
The little tikes gearbox assembly can be purchased at this site http://www.shopjandl.com/
but if you just need the push nuts like I did you get them here http://www.shopjandl.com/0801-0226.html.
I had the same problem, so all I had to do has tighten up those screws and replace the push nuts.
Hope this helps
Hummer tire not rollin
The Little Tikes Gearbox might be bad.
The motor came loose from the gearbox on my kids hummer, so the gears were not turning right.
You can also contact this website. http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
I got my parts from them and they helped me figure out what was wrong.
1helpful
Where do you plug the charger on little tykes H2?
The charger will plug directly into the battery, but it must be a specific little tikes battery charger because the connectors are slightly different than other battery connections.
The battery is usually located under the hood in front. I try to charge my batteries up at least 18 hours.
Hope this helps.
4helpful
Replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
