Question about Sony Ericsson K750i Cellular Phone
Light switch The light stays on and will not go off. Even when the battery has been removed and reinstalled the light comes on again and stays on
    Sergeant:
  • 452 Answers
Open the settings of your mobile there is option of DISPLAY SETTINGS in your mobile ,select the option of back light, than select the timings according to your needs
Posted on Oct 19, 2007
SOURCE:
1994 fatboy brake light staying on
Hi Anonymous, your front brake lite switch button is probably not getting pushed back into the off position. Remove your right handelbar switch housing and push the plastic button in and out with your finger to see if the light goes off and on. If not disconnect the wires to your rear brake lite switch and check the front switch button again. If the button works then reinstall the switch housing and push it towards the master cylinder hard and hold it with one hand and retighten the screws with the other. If you hook up rear brake lite switch wires and the brake lite comes on replace the switch. For a wiring diagram for your turn signals go to: http://officialharleyparts.com/wiring_diagrams.php Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2014 | 1993 Harley Davidson FLSTF Fat boy
My GE Universal Remote stopped working. I tried new batteries and reprogramming but cannot get the indicator light to stay on after I hit "TV"; therefore, I cannot input the code.
Try removing the new batteries and pressing all the buttons then reinstall the batteries and try again. Sometimes remotes get hung up due to a stuck button
Nov 28, 2012 | GE Universal Remote Control 3 Device Model...
MOBILE SHOWS CONECTED TO THE COMPUTER STILL IF IT IS NOT CONNECTED AND NOT DONE ANY WORK BECAUSE OF THE SAME
Remove the battery for sometime and keep aside. If the fault comes back even after the phone is switched back again then it is a fault within the phone software and might need a reinstallation. check also the charging pin , clean the socket and check once again.
Jun 28, 2012 | Cell Phones
I have a 1991 honda accord coupe. the taillights stay on all the time. what do i do to make them turn off?
the tail lights? theres two signals. is it the park lights stay on or the stop lights stay on??? is your stop lights stay on, go under the dash board right in front or behind the brake pedal you will see a switch. dicconect it. then check the lights again. if there off buy a new stop light switch and reinstall it. and recheck it again. also before you buy it, check the relay for the stop lights too. remove it and check. then put another from another function. huh horn, headligh a/c blower just to test it then put it back,. let me know
Jul 20, 2010 | 1991 Honda Accord
Brake problem
Switch on brake pedal stuck due to dust etc. Many new cars have a safety feature that allow the brake-lights to come on if the brake lever is depressed, even when the ignition is switched off.
If you can get to the switch, a good cleaning with methylated spirits and a small brush should allow it to move freely again. Good luck.
Mar 09, 2009 | 2002 GMC Envoy
Screen wont stay on
try to reinstall the firmware of your psp using pandora battery and magic memory stick or try to go to recovery menu hold press r button and switch on you psp and go to advance and select format flash1
Feb 07, 2009 | Sony Limited Edition PSP Daxter...
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Flashing light
pls flashing your mobile by software or reinstall software on your phone.
BYE........
ARYMAY DATTA
Jul 20, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
75 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
