Question about Olevia LT37HVS 37 in. LCD HDTV
White lines across top of picture
This happens intermittent not all stations or commercials
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Pending hardware failure - (problem with power inverter), get it serviced before warranty runs out.
Posted on Aug 26, 2007
SOURCE:
White lines and blurry across top of pictue
On our Sharp LCD this happened when the picture format was changed. We have a stretch function which caused this issue. If you go into your TV menu you may have the same type of settings depending on your TV. It happened to us mostly during commercials when the signal changed. We simply adjusted the screen sizing and it went away.
Mar 02, 2011 | Televison & Video
Recently had to upgrade my Direct TV box to an HDbox and now my standard television has a series of small white lined across the top of the picture. This does not happen with all shows or commercials, it...
It is due to the higher video level from your set top box. It may have a higher video level than the tv can accept. Try to reduce the level by capacitor resistor[R-C] network in series with video input cable.
Oct 13, 2010 | Sansui 32" TV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Denon reciver and white lines accross the top
try cable box Direct Connect to tv...if all ok ..need replaced receiver if sam problem replaced cablen box...
Apr 09, 2010 | Audio Players & Recorders
The picture is occasionally condensed completely into one thin line across the middle. What does this indicate is happening?
This is a frame collapse. If it sorts itself & then goes like this intermittantly then you will have a poor soldered connection either on the frame IC or surrounding components. If the white line is permanent then most likely the frame IC has failed & would need replaced.
Jul 13, 2009 | Panasonic Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Sound but no picture
A white like across the screen means that the vertical circuit has stopped working. Look for a small fuse that looks like a resistor near the vertical output IC, replace that fuse if open and resolder the pins on the vertical output IC.
Jul 08, 2007 | Toshiba CZ32V51 32" TV
Olevia LT37HVS 37 in. LCD HDTV Logo
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
