Question about Olympus EVOLT E-500 Digital Camera
E-500 autofocus problem
Today when i went to use my e-500 the autofocus would not focus
  • 1 more comment
  • tsubame Nov 06, 2007
    With my 14-45mm lens it tries to autofocus but instead it simply gives a little shudder and stays unfocused, it seems to be jammed and will not correctly focus, is this an electronic problem with the lens or is it the camera. this happens no matter how many focus points are used. please can you offer a soloution?
  • Trevor Stuckey Dec 15, 2007
    I have a similar problem but the auto focus light in centre of the view finder does not flash on either of 2 lenses, and the shutter does not operate continuously. I have rotated both lenses ,and cleaned the contacts with tissue, the camera is 5 months old and has worked fine till now.
  • grunderT Mar 24, 2009
    When I try to take a picture with my Olympus E-500 the lens will not focus on either manual or auto.  It seems the shutter is stuck.  I've tried different settings and recharging the battery without success.
  • 3 Answers
There is a bar that transfers the movement of the focusing ring to the motor in the back of the lens.  If it jumps out of the plastic slot, you will hear the AF motor turn, but it will never focus in either auto or manual mode.  You will have to buy a new lens, get the lens repaired (probably more expensive than buying a kit lens), or partially take the lens apart and re-seat the bar.
Here is a link showing how to fix it:
http://forums.dpreview.com/forums/read.asp?forum=1022&message=17650836
I did it successfully in about an hour with a set of jeweler's Phillips screwdrivers, tweezers and a strong lamp.  You MUST be comfortable delecate parts and tiny screws.  Then again, you have nothing to lose if you are going to buy a replacement lens.
Posted on Apr 10, 2009
Mine will do this at random and I simply have to remove the lens and re-install to correct it and it will focus from then on.
Posted on Nov 19, 2007
In auto focus, the camera uses 3 frame points and determines which one is best to focus on for that shot.  If there is too much going on in the photo, the camera cannot choose which point to use.  If this is the case, push the auto focus button on the upper right corner of the camera back.  Then use the control dial to select the frame point you want the camera to focus on (your options are: left frame, right frame, center frame or all 3).  Once you select the point you want, you should be able to take your picture.
Posted on Oct 30, 2007
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
Today my d70s suddenly can't autofocus,no beep sound n show r05.please help me anyone?
Does your lens have an aperture ring and, if so, do you have it set to the "A" setting? Have you tried cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol? Do you have the focus set to autofocus or manual?
Sep 19, 2010 | Nikon D70s Digital Camera
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
Jul 14, 2009 | Nikon D40x Digital Camera
Autofocus motor run but no focus
Found this myself check manual focus ring (closest to camera) maybe ring has moved to "manual"position. This ring moves backwards and forwards between "manual" and "auto" and may need pushing home completely
Dec 25, 2008 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
Nikon D50 Does Not Autofocus
replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
Nov 05, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 autofocus
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Jan 12, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Olympus EVOLT E-500 Digital Camera Logo
1,312 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
