Question about Philips Magnavox 20MT133S 20" TV
TV won't turn on just a clicking noise
The tv is off and a clicking noise is coming from the back. The tv was off when this clicking noise sounded then the tv wouldn't turn on.
  • 3 more comments
  • Glide8 Sep 01, 2007
    its the speakers making the noise like a thump thump.
  • geed man Mar 17, 2008
    tv is clinking in back and won't turn on
  • Julorena Jul 30, 2008
    I have the same problem with the clicking noise where the tv won't power up, but have no idea what switch peeps are talking about and where it is located or where the button is. Can someone give me a general idea where and what to look for? Thanks
  • toagac Sep 02, 2008
    I have the same problem. Ima tell you exactly what my problem is so i dont feel stupid later =)
    Problems:
    TV not turning on
    A heartbeat thumping kinda noise that seems to be coming from the middle of the left side(i also noticed another noise on the left side that sounded like maybe a pin dropping on a hard floor right before the thumping)
  • ejbauerly Nov 12, 2009
    having same problem can't find this button can you elaborate a little/
    Problem Solver:
  • 9 Answers
Ok this is a bit complex but im going to describe to you what you have to do\ 1) TAKE THE BACK COVER OFF 2) LOOK FOR WHERE THE SWICJ IS LOCATED 3) LOOSEN THE SCREW WHICH HOLDS THE BUTTON 4) CARRY ON LOOSEINNING BUTTON UNTIL YOU CAN PRESS IT 5) THEN CHEC IF IT WORKS IF IT DOES TITEN THE SCREW AND PUT COVER BACK ON IF NOT THEN CONTACK ME
Posted on Aug 27, 2007
Hi, i have the sae problem with clicking tv
and can not fond the swich you were talking about...
wich swich is that
how do i find it??
regrds
Posted on Apr 24, 2008
Have to say i had the same prob with the tv not turning on and clicking non-stop.what you said should work datadodo worked thx for the info and saving me cash lol.
Posted on Apr 16, 2008
3 Suggested Answers
graemevm
  • 519 Answers
SOURCE: Clicking sound in back of tv when you try to turn it on
Sounds like this could be a dry soldering joint in the TV power circuit. This can easily be repaired with a small soldering iron and soldering wire.
Best wishes,
Graemevm
Posted on Jun 06, 2009
  • 6 Answers
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Posted on Jan 03, 2010
Samsung 13 tv can't get it to run what can I do?
As you and I don't know what the problem is, certain basics have to be first covered. Here is a link describing basics for any TV.
TV Power Light Comes On But No Picture Or Sound
As I don't know if you have an active led power light, here are a couple of videos:
EASY HOW TO FIX SAMSUNG TV NO POWER
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
Samsung TV Won Turn On Has No Power No Standby Light Samsung LCD TV...
If the set is powered up, you can try resetting it to factory defaults. Yes, any of these suggestions may not work but one of them might fix your problem. You might try searching for tips by including the model number in the search. Bear in mind you are dealing with a high voltage device and your next repair may be at the hospital if you are not exceptionally careful.
Feb 28, 2018 | Samsung Televison & Video
I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
Aug 19, 2011 | Samsung PN42A400 42 in. Plasma TV
Tv started making a fizzing noise and now it is clicking as well with a slight movement of the screen during the click noises, goes up and down in volume now for a few days
is the fizzing noise when the screen is really bright? if so the scan coils on the tube have come loose and need glueing down with nail varnish i know it sounds strange but it really works
if the fizzing is coming from the tv then you have whats called dry joints
and this will need to be resoldered or the tv will shut down if you can do this yourself then the best way to find them is to remove the back and turn the tv on its side turn on the tv and turn off the light you will be able to see the dry joints sparking on the baord
hope this helps
John
Jul 06, 2011 | JVC AV32F476 32" TV
MY Samsung LN40A650A LCD TV MAKES A CLICKING NOISE AND WON T COME ON NO PICTURE AND NO SOUND
Clicking sound on LCD TV mostly from incorrect voltage supply for main board, that problem because some part damage or short. Capacitors can make this problem. If you have electricity experience , you can open the rear cover than see if any damage part or blown. For detail Try this.
Good luck.
Apr 08, 2011 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Phillips 42pf9630a 42 in
A code 7 is related to a hardware problem that reqiures service.
If you want to get a referal to a Philips authorized service center call 888-744-5477 and they can prive contact info for a servicer in your area.
Aug 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Philips Magnavox 20MT133S 20" TV Logo
3,211 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
