Question about RCA HD61LPW175 61" Rear Projection HDTV
32 inch rca color
Suddenly color went out of wack. looks like giant finger print in mddle of tv. color around finger print. light green color in middle of finger print. tv is 2 years old average use.
  • 398 Answers
If this is a 32 inch TV then it is a standard picture tube set. If the colors have suddenly gone out of whack, and the set has not been dropped or had any large magnets near it recently, it means that the degaussing thermistor has come loose from its legs. This is very common in the RCA regular picture tube sets. If you look in the back of the set you will see a large black coil of wire wrapped around the edges of the picture tube, with 2 white wires going down to a jack on the main PC board. Right next to that jack is the degaussing thermistor, which looks like a small silver disc, like a nickle, with 2 legs loosely soldered to its sides. One or both of those legs are probably loose, and if you are very careful you can solder those legs back onto the thermistor. If you do not have experience soldering small parts, allow a qualified tech to handle it for you.
Posted on Aug 28, 2007
SOURCE:
Need to order a new engine light for my 72A650
started with different color pixels not coming in till the tv warmed up. Hadf to turn TV on and off several times before clear screen. Last night TV went black with a giant red x in the middle of screen. Now just 99% black.
Jan 14, 2014 | Samsung SELECT HL72A650C1F Rear Projection...
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
The color on my tv is out of wack. It seems to have happened all of a sudden. mostly green, and no red.
if ur using the hd input make sure the cables are not loose also try deferent input , if the problen still there than u have a bad optical block
Aug 25, 2010 | Panasonic PT-61DLX75 61" HDTV
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Rca 32 inch hd tv wont turn on
Josh,
Take your unit to a service center where they repair tv in your city.
Ask them to repair it. Because there are no repair manuals they will not repair.
Make sure they use a work order. when you pickup your tv.. make sure you get the work order or a copy.
With that order... call 1-877-297-8391 and get a new tv
Apr 11, 2010 | RCA L32WD22 32 in. LCD HDTV
My TV started showing light green color in the white areas. Then about a week later when using the auto focus, it stopped when the green focus came up. Short after that the screen went out of wack, waves...
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 20, 2009 | Toshiba 42H81 42" Rear Projection...
Rca scenium 50 inch dlp. i now have 3 black blotches in the screen. they look like giant finger print smudges. very noticable on light colored screen.
You have a problem in the light engine portion of the set. Somewhere in the optics. It could also be a build up of dust or a foreign substance. Have a repair shop give it a good cleaning inside. You may want to pull the bulb and make sure there is no foggy places inside of it. Thanks
Oct 28, 2009 | RCA Televison & Video
RCA HD61LPW175 61" Rear Projection HDTV Logo
141 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
