Question about Samsung RS2630SH Side by Side Refrigerator
Freezer not working
Recently the freezer stoppped cooling, i have removed the panel to get to the fan, i cant see any reason why the fan isnt working - is there any other common problems that my stop it working?
  • deano100 Aug 26, 2007
    Thanks Krazytech - done that and discovered the motor has indeed gpne, the problem i have now is finding a replacement! Any ideas??
    Cheers - just found one on myspares.co.uk - thanks for your help.
  • 725 Answers
You may have a bad (open) fan motor after unpluging the freezer check the motor see if you can turn it easly then unplug the motor and check it with an Ohm Meter. You should have continuity thru the motor.. let me know what you find out...
Posted on Aug 26, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 26, 2007
    check a local appaliance parts warehouse to save on shipping or check the internet for a Evaporator MOTOR FAN-AC Samsung DA31-00103A $36.07
SOURCE:
I recently scored a bargain Fisher Paykel stand-in fridge/freezer because my original fridge developed a fault. sadly the stand-in Fisher Paykel N405T has an issue of its own, the freezer doesn't really...
Yes ur correct. the fan can be accessed by removing the back panel wall from ur freezer dept. sometimes u will have to remove the bottom panel first a couple screws are all it takes
Mar 31, 2015 | Fisher Refrigerators
The bottom of the freezer gets cold , the Fridge gets nothing
The refrigerator compartment is cooled by the cold air from the freezer. This air is blown in through a vent between the freezer and refrigerator compartment by the evaporator coil fan in the freezer. If the vent is blocked or the fan is not working would be the reason that the Bottom is cooling but the refrigerator is not.
To troubleshoot, you must remove the panel that covers the evaporator coil in the freezer. You will need to remove the contents of the lower section of the freezer to get access to the panel near the bottom of the freezer. Once the panel is removed, you should be able to confirm whether the fan is spining. If it does not turn and it is plugged in and the refrigerator is not in defrost mode, then the problem is with the fan motor.
If the fan is spinning but you notice ice buildup on the coil, the problem is with the defrost circuit. Typically the failures are with the defrost timer not functioning or that the defrost heater has failed.
thanks for rating good luck
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
My frig is not cooling the temp is currently 68 but the freezer is fine any ideas
The refrigerator compartment is cooled by the cold air from the freezer. This air is blown in through a vent between the freezer and refrigerator compartment by the evaporator coil fan in the freezer. If the vent is blocked or the fan is not working would be the reason that the freezer is cooling but the refrigerator is hot.
If the fan is spinning but you notice ice buildup on the coil, the problem is with the defrost circuit. Typically the failures are with the defrost timer not functioning or that the defrost heater has failed. Hope this helps you.
Jul 22, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer working well fan stoppped and refrig not getting cold
There is a new replacement fan available for your refrigerator, it comes as a kit with a new mounting bracket. They had a lot of issues with this model. You can replace it yourself- it is located in the freezer compartment behind the back wall and has 3 wire connections and a clip in style mounting bracket. You may have to remove the ice maker if you have one to get the back panel out.
Jun 14, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer cold but fridge warm
first leave it off for 24 hours, and then put it back in operation. if its doing it again , then chck the heating element, defrost timer...
Apr 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Mar 25, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator does not work but the freezer works fine!
most fridges are cooled by the freezer. There is usually a fan in the freezer section that blows cold air in the fridge section vial some duct work. I expect that the fan has failed or that the air passage is blocked. look inside the fridge, near the very top on the side next to the freezer. You should see a vent/grill.
Jun 22, 2017 | Refrigerators
Freezer doesn't work
Hi Andy you may have a bad (open) fan motor after unpluging the freezer check the motor see if you can turn it easly then unplug the motor and check it with an Ohm Meter. You should have continuity thru the motor.. let me know what you find out... krazytech
Aug 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
127 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
