P52151WK 52" projection TV, no video
I have an RCA Home Theater 52" projection TV that has always performed like a champ, but now there is no picture at all. The sound is still awesome but absolutely no video. I've opened the back panel to get a look at the tubes and they do not light up at all, as if they are not getting any power. I don't recall anything happening before this happened. The video simply stopped working but sound has always worked great and still does. The unit is RCA Home Theater model #P52151WK, chassis #PTK169PTB
  • 12 more comments
  • twinsdad Aug 30, 2007
    You were spot-on! Took just an hour to diagnose, with your info, and the TV once again works like a champ. Thanks!!
  • AAAA12410 Nov 09, 2007
    I have a phillips 50P8341A and was fine then the next day I tried turning it on and the power light turns on and it makes a fuzz sound but there is no picture, can someone give me any suggestions?
  • Chatham48 Jan 02, 2008
    I have a zenith A50M91W Projection TV. When I turn it on the picture and sound works fine. After about 5 minutes the picture goes out and the sound stay on. If I leave the power on the picture eventually returns. In a 1/2 hour or so.
  • Anonymous Feb 08, 2008
    Same problem. No video and perfect sound. I wish I could find the solution!
  • toap Feb 25, 2008
    i have the same problem with my proscan 52in rear projection. sound is there but there is no video. my wife was watching but after few mins. the picture just start fading away and then no video at all. pls help. wasif.
  • chris1461 Feb 29, 2008
    no power at all it comes on and go right back off
  • Anonymous Jul 04, 2008
    I have a Mitsubishi HDTV Model# WS-65907. When I power it on no picture will appear. I can hear the sound but no picture will appear. What should I do? Thanks.
    I have a Mitsubishi HDTV Model# WS-65907 and it will not produce a picture. What should I do? I can hear sound but no picture will appear.
  • my1vett Jul 06, 2008
    I have a 60 inch projection TV. All of the color bulbs have been replaced. That didn't seem to fix the problem. It seems like it is not getting enough power to make it work.
  • el jacko Sep 09, 2008
    I have a similar issue in that no video is available if I use the standard RCA video inputs (on all 3 of the video inputs front and back of TV). However, I do get a picture if I use the component video RGB cable inputs on the back of the TV. I'm pretty sure there is sound if any of the audio cables are connected. The TV was working fine until I moved it from Florida to California. Any ideas??
  • hillsriders_ Oct 15, 2008
    picture is out but when i bang or wiggle wires sometimes it comes back on i can also hear a crackling noise or zapping noise from the front right side of tv
  • hsrhawaii Oct 29, 2008
    Tv comes on but with no video or sound. One minute it worked well and the next time we turned it on, the timer and lamp lights flash, no picture or sound comes on and then it turns itself off.
  • Anonymous Nov 07, 2008
    Same Problem. Great audio, no video. Chirpping sound when I start it, then the power button blinks 6 long blinks then 1 fast blink. Any ideas?
  • Anonymous Jan 16, 2009
    no video but sound on my rca projection tv.
  • 5,138 Answers
BAD FBT flyback transfomer
Posted on May 21, 2009
  • 398 Answers
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Posted on Aug 28, 2007
  • Nathan Green Jul 05, 2013
    I think what you have said is my problem My RCA Theater Projection Tv has never had a problem I have had it for 17 years now no picture or sound just a soft beeping noise from the back. thats it.
SOURCE:
I have an RCA 52 " projection TV thats now 6 years
you have to run theater system eather through your vcr or your dvd player for mor out put jacks and input jacks on older tvs but the thing is your dvd player remote will be your tv remote the same as your vcr remote.
Feb 13, 2011 | RCA P52937 52" Rear Projection Television
Rca television home theater premier 52' went out of focus how do i fix
unplug the TV for 4 hrs. and it will reset to factory settings maybe that will help and then you have to run setup again of course.
Jan 02, 2010 | RCA P52937 52" Rear Projection Television
I have an RCA Home Theater 52'' projection TV that has always performed like a champ, but now there is only 3/4 of the picture showing. The sound is still awesome.
Hi,it sounds like a DMD issue if your tv is a DLp.This is how it works: http://electronics.howstuffworks.com/dlp1.htm The Dmd is basically where the image is created it will be the actual screen.When it starts to fail picture will be chpped or pixilated like what you are getting.God bless you!
Oct 16, 2009 | Televison & Video
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
2,261 people viewed this question
Top Televison & Video Experts
Ekse
