SOURCE: on a rolex watch, does it have to have the serial
Numbers on case back are inside. Number on case is outside, located between lugs. You need to remove bracelet to see it. Rate me, plz.
SOURCE: I had my Rolex watch serviced 2 years ago By Rolex and now
Either the stem or latch needs to be replaced. It's a common problem for ALL manual wind watches.
SOURCE: Match the year of my Rolex Explorer 1 from the serial number
I would expect Rolex to have a record of all their watches and if you contact your nearest dealer, they should be able to help you.
You can find a store guide on their web site "rolex.com"
SOURCE: where are the model number and serial number on a
Thank you for contacting FixYa. Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different. Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step. Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar. Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase. The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues. Hope this helps. Jewel
For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
SOURCE: ROLEX SUBMARINER 27JEWELS MODEL NUMBER
There should always be a serial number on the back of the case period. If your Rolex does not have any indicators on the back it is not authentic. Sorry. One thing to always note is if you get a 10x eye loop and look at the writing on the case and bracelet if you notice it being sandy colored and or punched several times rather than one smooth form this is also not authentic.
Regards,
Tony
