Question about AT&T 9353 Cordless Phone
Can't Hear Messages Even at High Volume
Even with the volume turned up, messages left for me are garbled and hard to understand. I thought I would see if there was some reboot or other suggestion that I could try before getting a new phone.
2 Suggested Answers
SOURCE: I can hear messages being left but they won't play back
I had the same problem.
For some silly reason, there is an option of not leaving messages. You will see "AO" in the upper right-hand corner of the phone. This is for Announce Only.
To take it off:
Press/hold SET UP
Listen until you hear "Selected Announcement is A."
Press skip/repeat to save
(The other option is going to be the Announce Only which you don't want, so you can play around with the setting to make sure it's the right one.)
Call yourself to be sure you did it right.
You should now have numbers in the upper right-hand corner instead of AO.
Posted on Apr 24, 2009
  • 14 Answers
SOURCE: attt phone 1455 answering maching-volume
throw it away and buy a good one
Posted on May 31, 2009
0 characters
1 Points
Get volume to turn up or purchase same phone that will work with my 2 extensions.
sad to say they do not make phones the same for very long .can you hear fine with the other 2 extension phones .
Jul 31, 2015 | Uniden Phones
My KX-TG4031 does not ring. I only hear the messages when someone phones. How do I turn on the ring tone?e
Open menu and scroll to see tones and ring volume. you can set this up to a desired level as it will ring to indicate the level. The volume also can be pushed up or down on the control pad. If this is not working there is fault on the ringer circuit. check if the ringer is switched off or put to silent.
Oct 04, 2011 | Panasonic KX TG4031 Cordless Phone
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
Please give me positive feedback if this helps you.
Feb 23, 2011 | Panasonic KX-TG2431 Cordless Phone
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Uniden Model FP204 Even with all controls on high
GAVE UP Obvious fault with the Model Hard to hear even with all
Volume controls on high
Jan 13, 2010 | Uniden Phones
How do i retreive my voicemail on my vtech 5.8 phone?
Hello, Below are the instructions for voicemail retrieval for your Vtech CS5121-2 5.8 GHz Twin 1-Line Cordless Phone. I have included an easily clickable and printable PDF link of the user's manual for this phone from the official vtech web site. I hope this helps you!
- CBR2009
New message indication The message display counter will flash when there are new answering system messages. If the new message alert tone is turned on, the telephone base will beep every ten seconds when there are unreviewed messages. Message playback Press /PLAY/STOP to listen to messages. Press /PLAY/STOP again to stop playback. If you have new messages waiting, you will hear only new messages (oldest first). If there are no new messages, the system will play back all messages (oldest first). When playback begins, the total number of messages is announced, followed by the day and time of the first message to be played. Options during playback Press VOL+/VOL to adjust the speaker volume. Press >>/SKIP to skip to the next message. Press<</REPEAT to repeat the message currently playing. Press <</REPEAT twice to listen to the previous message. Press X/DELETE to delete the current message. The system will advance to the next message. Click below for PDF USER'S MANUAL
Aug 18, 2009 | Vtech CS5121-2 Cordless Phone
How to turn ringer off, while keeping line open for messages
Go to handset settings.. then ringer settings, us left arrow to make the ringer less, press until the reading says volume OFF. To bring ringer On press right arrow to choose ringer volume.
This must be done on all handset you have.
Hope this helps
Oct 11, 2008 | Phones
AT&T 9353 Cordless Phone Logo
26 people viewed this question
Top AT&T Phones Experts
Are you an AT&T Phone Expert? Answer questions, earn points and help others
