Question about GE Profile JT915 Electric Single Oven
Oven/Broiler fails th heat
Pretty simple. Select Bake, set temp and oven does not heat. Broiler does not heat.
  • Glenn02 Aug 26, 2007
    Thanks !
    I have a cooktop installed over the oven.
    I ma not sure if I am going to pull the cooktop or the oven.
    But its a brand new oven, so I am definitely callng GE first thing Monday morning. Its under warranty and I do not want to void the warranty. I wil post a message when its resolved.
    Thanks for the quick reply....at least I know its not something I did...
  • 725 Answers
Sounds like a bimetal switch is blown. first I would check SWITCH LIMIT BIMETAL next the LIMIT SWITCH-UPPER(LOCK) Too check them first trip the breaker so you don't have power to the oven, then you will have to take the oven out of the wall..next remove the top cover. then in the center-front there are two round bimetal switchs with two wires coming out of them..remove the wires and check them with an ohm meter both should have continuity across them ...if no continuity you have a bad switch. let me know what you find out..
Posted on Aug 26, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 26, 2007
    LUCKY you have the warranty... I would also get a extended warranty if you can GE parts have outrageous markups on replacement and have horrendous quality problems.. better yet see if you can return it.. go out and buy any another brand other then a GE if you can stay away form jenn-air or thermadore way to many problems too
SOURCE:
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
OVEN TEMP STUCK ON 100F
check your house connections to the stove turn the breaker off first then reply to me
Jun 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
GE Profile JT915 Electric Single Oven Logo
135 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
