Question about Electrolux EW1000i Front Load Washer
Very noisy drum
How do I replace the bearings on this machine
  • gixxer16 Apr 26, 2008
    our indesit front loading machine makes bad knocking sound when spinning...can anyone help please
  • 126 Answers
To replace the bearings, you need to replace the whole backside of the outertub. Pretty difficult!
Posted on Jan 24, 2008
SOURCE:
Servis 1200 very noisy in spin modes. Inner drum seems to be very loose and wobbly. Noise sounds like a roller with flat spots running on the drum, or a very bad (failed) bearing. Machine is 12 years old,...
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
Sep 09, 2013 | Washing Machines
Cause of noisy spinning
your drum bearings have gotten water into them from a defective inner drum lip seal,now you need to tear down the machine and replace the lip seal and also replace both inner and outer drum bearings
Apr 18, 2010 | Zanussi ZWF1430W Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Very noisy Hoover VHD9143ZD washing machine - just 2 years old
yes bearing housing get loose in plastic drum. needs drum replacement.
Oct 29, 2009 | Candy Washing Machines
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Washing machine really noisy on spin!
    Probably main drum bearings worn
    If you turn the drum by hand and it feels rough or noisy ,then definately bearings worn and noisy.
    Nov 19, 2008 | Washing Machines
    Bearings very noisy on the drum
    aquarius w f 541 1400 spin drum bearing noisy
    Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Hotpoint BWM - very noisy but not walking accross the floor!
    Remove the back of the machine to expose the inner drum pulley. Need to know if this pulley is rotating and if there is any side to side play.
    The noise you are discribing does sound like a rear bearing that is mounted in the external tub housing. Depending on the age of the machine, this bearing is NOT replacable. The outer tub must be replaced because the bearing is molded into the drum.
    Jan 02, 2008 | Hotpoint BWM12 Front Load Washer
    Wm noisy
    drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
    Sep 25, 2007 | LG WD-16110FD Front Load Washer
    Electrolux EW1000i Front Load Washer Logo
    135 people viewed this question
    Top Electrolux Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    jimorris77
    Poppa Maddo
    Poppa Maddo
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
