Question about Sony Handycam DCR-TRV280 Digital Camcorder
Out of focus/flashing code
When in record mode, focus is blurred and display flashes "E:61:10" from time to time.Tried searching through menu but not sure what this is related to.If its an autofocus problem I didnt come across that option.
  • 169 Answers
That problem is on the lens assembly...one the two motor is not working properly...sometimes it is a poor connection to the socket of the main board...other is photo sensor of the lens(not the ccd image sensor)or the driver ic of the 2 motor...i suggest you have to go the service center for repairing you camera cause it need to disassemble the camera for doing this....
Posted on Sep 02, 2007
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.
The manual is still online.
Success
Jan 13, 2014 | Sanyo Xacti Cameras
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
How do you turn off the flash on samsung sl202
When the menu is displayed on the LCD monitor, pressing the LEFT button makes the cursor shift to the left tab. When the menu is not displayed on the LCD monitor, the LEFT button operates as the FLASH ( ) button.  Selecting the flash mode 1. Select a desired Recording mode, except the [Movie] mode and the [DIS] mode. 2. Press the Flash button until the desired flash mode is displayed on the LCD monitor 4268flashicon.jpg The flash does not fire. Select this mode when capturing images in a place or situation where flash photography is prohibited. When you capture an image in poorly lit conditions, the camera shake warning indicator ( ã ) will appear on the LCD monitor.
Oct 24, 2009 | Samsung SL202 Digital Camera
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
FOCUS PROBLEM
So... there's poor focus, and there's shutter speed.
If the light is very low, the shutter has to stay open for longer to allow enough light in to make a bright picture. Suffice to say, if you move around while the shutter is recording, it will record you moving around, and it will look blurred. That covers the concert you went to. Just use the flash. The camera will know it can use a very fast shutter speed if the flash is going to go off.
As for the person in the background thing... if they are the only blurry thing, then it's the same as above. If not, try this:
Check your camera setup menu... you should have focus options. Most toy cameras have an auto-focus that can focus on multiple points in the shot, or one point only, or even by face recognition these days! Try using a "spot focus", one focus point in the dead-centre of the shot.
On this setting, it shouldn't matter what is going on around your subject, the focus spot will be in the centre, where you are aiming it. =-]
Apr 22, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
How do I turn my flash off on my samsung digimax 4010
You don't say which model Digimax you have. Hopefully this will cover most models.
First, make sure the menu is not being displayed on the LCD monitor, otherwise you'll just move around in the menu screen. You must also be in photo record mode, ready to take a picture (not in playback or movie mode).
There is a button (usually on the left side of the direction pad) that looks like a lightning bolt. I can't remember the exact number of times you must press it, but the display should indicate that the flash is turned off as one of the options as you cycle through them.
Depending on your model, the modes are likely to be Auto Flash (bolt with an "A" icon), Auto with Red-eye reduction ("eye" icon), fill flash - always on ("bolt" icon), Slow sync (bolt with an "S" icon), and flash off (bold with a line through it icon).
Also depending on your model, you may not be able to turn the flash off depending on which recording mode you're in. For instance, you can't turn the flash off if you're in the "Backlight" recording mode.
Dec 13, 2007 | Cameras
Flash
the left tab.
■ When the menu is not displayed on the LCD
( ) button.
● Selecting the flash mode
mode with the exception of MOVIE CLIP mode.
LCD monitor.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
BLURRED PICTURE WHEN USING MOUNTED FLASH.
If you are not using canon lenses then the low light focusing aid will not work correctly. Go into the menu and turn of the flash infra red light
Jun 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Picture still blurred on record mode
Your problem sounds like a focus problem. Could be that it's on manual focus and you're hitting the sweet spot only in full zoom? From the manual: 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button.  M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus.  Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again. Hope it works out, let us know!
Jun 03, 2006 | Samsung SC-D103 Mini DV Digital Camcorder
Sony Handycam DCR-TRV280 Digital Camcorder Logo
60 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
