We bought a samsung 19" monitor in december 2008. it was working fine until this week. after turning the computer on, the screen came up black except for the box saying "out of resolutiopn mode 1440 x 900. i have talked to samsung technicians and one from dell and no one gives me the same answer. the resolution on our computer is 1428 x 768. i cannot change the resolution. that is as high as it will go. the samsung technician says the monitor will not come up until the resolution question is solved. but why did it work at the 1428 x 768 resolution for 3 months if the 1440 x 900 is required. one person said the monitor was defective and another said we needed to get a new video card. what do you think?
SOURCE: screen resolution
hi
right click in your desktop,left click in properties,click on settings then change resolutions apply and ok.
by by.
SOURCE: widescreen resolution...
Every video card has it's max resolution. To see what your max is for the d530, if your running a version of XP. Open Control Panel. Open Display. This will open Display Properties. Click the Settings Tab. Listed there is screen resolution, sliding the marker all the way to More will give you your Max resolution. I have a high end video adapter & my max resolution only goes to 11280x1024. You may have to contact HP/Compaq. The link listed contains updated drivers for the d530 but there is a bunch listed because each d530's have different internal devices.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11360
You can chat with HP/Compaq at this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ContactHP.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713
This is your best shot! Good luck.
Please vote...
map
SOURCE: Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
SOURCE: Resolution Issue "Not Optimum"
Hi Guys.
I have had this problem and after a bit of searching found that it is a known problem.
Give Samsung a ring and if it's in warranty they will replace it
SOURCE: monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
The reason why might be because your video card is outputing a higher resolution then the 1440 X 900. What OS are you running and what video card do you have ?
