Question about DE-1733 Radar Detector
No audio run auto test no audio. try to set back to factory set by holding the power and quit mode in at the same time then pluging unit in no response. help please
  • Whistler Expert
  • 347 Answers
Model 1733 doesn't have feature memory and thus doesn't have a factory reset. Is the volume turned up?
Posted on Feb 11, 2008
Hi;my Yamaha receiver RX-V 373 will not turn on. No power. No display. It may be that the unit went into protection mode. Can anyone there, help me, restart my unit back to factory condition?
If you have power it should click before protection mode and have a light showing it's in protection mode.
After the transformer there's some resistors that have failed if it's in protection mode normally it's one or two that have failed, you can get the reading of what they should be by testing them
Apr 17, 2016 | Yamaha Audio Players & Recorders
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
HI I have a Yamaha RX-V367 Amp and I need to reset it back to Factory Settings.
In order to restore the unit to factory settings:
  • Please put the unit into standby mode.
  • Then hold the power button while holding the "straight" button on the front panel of the unit.
  • After approximately 3 seconds "Advanced Setup" should be displayed on the front panel of the unit.
  • From this menu select "init" and then all.
This will restore all factory settings.
For a digital copy of the owner's manual please reply in this thread.
Feb 28, 2011 | Yamaha RXV367 Receiver
Alarm is orange, and is pulling a E3
Take the cartridges out and left the lid up, unplug it, plug it back in with finger on the power button and tap the stop/reset button twice. Put the cartridges in, press the color start, a test page should print. unplug it again, plug it back in .
Try an EEPROM reset:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Why can i not charge my 1300nuvi on the car charger without the satnav switching its self off with no power am i pluging it in wrong
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 03, 2010 | Garmin nuvi 1300 Car GPS Receiver
Radio and clock will not work. The fuses are good i think.
Check fuses first. please rate as fixed if this solves you rissue. report back results.
Mechanical Electrical
  • Integrated control panel with or without tape player physically damaged, misaligned, any controls inoperative.
  • Digital audio compact disc player physically damaged, misaligned, any controls inoperative.
  • Radio antenna lead in cable, electric antenna or bodyphysically damaged or misaligned connections.
  • Radio speaker mounting/speaker cones physically damaged, misaligned.
  • Radio ignition interference capacitor or radio frequency interference suppression bond misaligned, unclean and no metal-to-metal contact.
  • Mobile telephone transceiver; mobile telephone handset, mobile telephone microphone, mobile telephone transceiver holder cradle physically damaged, misaligned.
  • Open fuses: fuse junction panel fuses 8 (5A), 12 (5A), 20 (5A), 22 (5A), 24 (5A) or power distribution box fuse 17 (20A).
  • Open connectors.
  • Corroded connectors.
Section 15-00: Audio Systems—Service 1999 Taurus, Sable Workshop Manual DIAGNOSIS AND TESTING Inspection and Verification NOTE: Many customers do not understand the limitations of FM reception. Refer the customer to the Owner Guide for information about the limitations of FM radio performance.
Internal diagnostic examination of the integrated control panel, rear chassis unit and audio compact disc player should be left to the authorized radio service center. However, the automotive technician should be able to analyze and isolate radio reception conditions to the proper area or component causing the condition. All radio conditions can be isolated to one of six general areas:
  • antenna system
  • integrated control unit
  • radio speaker system
  • radio noise suppression equipment
  • rear chassis unit
  • audio communications protocol network
Retrieving Diagnostic Trouble Codes (DTCs)
Using Audio System On-Board Diagnostics
The audio system has on-board diagnostic capabilities and is equipped to check for every component available in the system even if this specific vehicle is not equipped with all components. A Diagnostic Trouble Code (DTC) will be set for the missing components. These DTCs can be ignored if the vehicle is not equipped with these components. The battery must be fully charged for proper audio system operation. The ignition switch must be in the RUN or ACC position. Turn the system on, tune in a strong AM station and verify good reception. After an AM station is checked, tune in a strong FM station. The system is now ready to enter the diagnostic mode. Diagnostic Mode:
NOTE: Battery must be fully charged for proper audio system operation and self-test.
Enter Diagnostics mode by pressing SEEK DOWN button first and then pre-set button 3. Hold both buttons for five seconds. This will suspend all normal radio functions, retain the previously selected frequency and display DIAG.
  1. NOTE: To perform diagnostics, press the appropriate buttons as instructed.
    Press pre-set button 1. This will check for connection of all possible devices and log the diagnostic trouble codes for any device that does not respond. The display will flash SELF while gathering the diagnostic trouble codes, then stop flashing when complete. To exit System Configuration Self-test, press pre-set button 1 again. To retrieve diagnostic trouble codes, press the TUNE UP button. This will display the diagnostic trouble codes if any exist. Continued pressing of the TUNE UP button will display the next diagnostic trouble code. Record codes and refer to the following table. To exit the Retrieval Mode, press pre-set button 1.
    CONFIGURATION SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit 2 No response from tape deck 3 No response from bezel microprocessor 4 No response from compact disc player 5 No response from steering wheel controls 6 No response from rear seat control 7 No response from remote climate control 8 No response from navigation module 9 Read Only Memory verification failed
    Remember, system configuration will test for all possible equipment connections. Inspect the vehicle to determine actual equipment installed.
  1. Integrated control panel display test:
    To enter the integrated control panel display test, press pre-set button 5. This check will light all segments in the integrated control panel. The system will automatically exit this test after five seconds.
  1. Integrated control panel and rear chassis unit identification:
    To enter this test, press pre-set button 3. This test identifies the software level of the integrated control panel and rear chassis unit. The integrated control panel is tested first, followed by the rear chassis unit. The completed test will exit automatically. For code identification, refer to the following table. The display will have two sequences of five codes each. The first sequence is for the integrated control panel, the second sequence is for the rear chassis unit.
    Item Part Number Description 1 — Product Type Code 2 — Product Variant Code 3 — Software Version Level 4 — Software Version Release 5 — Software Version Patch
Apr 23, 2009 | 1999 Ford Taurus
Kenmore HE4 Dryer leaves clothes wet
From the techincal document found in the dryer bottom panel
TEST #4a Dryness Level Adjust
NOTE: If the customer is complaining about the clothes being damp and the moisture sensor passes TEST #4 "Moisture Sensor Test- step 3, then the total dry time can be lengthened by changing from a "Lo" for short auto cycle to "Hi" for longer auto cycle.
1. Activate the Diagnostic Test Mode. Press the following button sequence: MORE TIME ~ LESS TIME -+ MORE TIME --+ LESS TIME - all within 5 seconds
1. In diagnostic test mode, press and hold the Auto Dry Level key for 5 seconds. The dryer will beep and the current auto cycle mode will be seen on the display. The factory default setting is "Lo".
1. To select a different auto cycle mode, press the Auto Dry Level key again. The dryer display will flash and show either "Hi" or "Lo"
1. With the display flashing the selected auto cycle mode press the Start key to save the setting and exit diagnostics (the Start key in this mode does not start a drying cycle). The result will be stored in EEPROM of the control board.
Feb 28, 2009 | Kenmore Elite HE4 Electric Dryer
Can't change the clock time
Best Solution posted Nov 6, 2008, by Guest -- worked for me. Wondering what the DST is? -- Daylight Savings Time. There will be a button at the bottom right in the date OFF. Apparently the TV Guide programing does not work that well, especially with the new Digital boxes now need to receive over the air TV and the TV Guide programing never worked with Satellite TV. Wil this feature ever be up dated? I doubt it. It would be nice to have the digital box and your dvr cycled together.
Nov 03, 2008 | Panasonic DMR-E85H DVD Recorder
Stuck in Stand-by mode and will not turn on
try to soft reset the recievers by unplug for a while and replug and try power on , or hold up the rear reset butomn and press power at the szame time then release both
Apr 30, 2007 | Pioneer VSX-D912 Receiver
DE-1733 Radar Detector Logo
82 people viewed this question
Top Whistler Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
