Question about Innovage 69420210126 Phone
Hand free hands free is always on
  • 2 more comments
  • mhelman Aug 27, 2007
    no whare in the manual does it give me the option to turn off the hand free do you know how?????????
  • Anonymous Dec 11, 2007
    how to set date and time on
  • rawdonbob Feb 17, 2008
    hands-free is always on even when the indicator is off. as soon as i pick-up the receiver the phone puts itself in hands-free mode
  • Anonymous Mar 21, 2014
    Turn on hands free speaker
    Problem Solver:
  • 17 Answers
Turn it off in options. :)
Posted on Aug 26, 2007
SOURCE:
My mercedes e class 54 reg had power down my stereo I change the fuse power came back but it shows mute mode does not give any sound when my engineer put on his computer its works then mute again
Hands free mute is caused by a switch grounding the radio , if you have a hands free kit it is permanently grounding causing MUTE , if it's a short to ground check wiring loom in car always test loom with a multimeter
Nov 27, 2014 | Cars & Trucks
I have a ford bronco 2 it feels like i am always pulling something behind me what should i be looking for
check that all the brake calipers are free to move on their mounting pins (dragging brakes) Check that the rear wheels are free to spin when the hand brake is off (dragging hand brakes). IF you are in 4wd and on hard surface there will be drive line wind up torque that is loading up the gears and wheels making them hard to turn as they are fighting each other because the wheels are not free to slip and relieve the pressure.
Feb 16, 2014 | Cars & Trucks
Is it safe to put chemical hand warmers elsewhere besides on hands?
Hand warmers usually come with a warning that says they should only be used on hands or feet. Like any product you always have to follow the instructions on the box carefully.
Jul 09, 2012 | Camping, Backpacking & Hiking
Want to know the steps on pairing the samsang woo 200 hands free bluetooth to my htc inspiree
First, Switch off your bluetooth hands free.
Now, press and hold the multifunction button for approx. 8 seconds till blue light appears.
Now, in your inspire, go to settings, "Wireless and network", Bluetooth. Turn on bluetooth and click scan device. It will show your bluetooth headset. Click on its name. It will ask for pairing code. Enter "0000".
You are done
Jun 07, 2011 | Cell Phones
I HAVE A 1997 F-150 4X4 EXT CAB,,THE HORN AND CRUISE DONT WORK,,,CHECKED ALL FUSES AND RELAYS,HORN WORKS WHEN I JUMPER THE RELAY 5 ON FUSE BOX UNDER HOOD,,,CHANGED CLOCK SPRING STILL NOTHING WORKS,,,CRUISE...
Hello Trainerdann,
Some troubles just HAVE to be traced (hand over hand):
My best recommendation will be to start with the HORN
& go hand over hand with the FACTORY drawings....
There is always that little INFO about ripping ....,
(what .aren't you telling us... Any relay swaps
(or bullet holes)) you have not mentioned.
Totally FREE circuit Drawings & Technical Service Bulletins
(TSBs) are available on the BBB Industries website...
Registration is required... (These are REAL documents)...
BBB Industries Premium Alternators Starters Power Steering Products
The only problem... Every time you return from the
DRAWINGS you are in the Technical Service Bulletins...
and must switch back to "WIRING"... but FREE... helps.
I hope I have.
Carnac the Magnificent
Jan 14, 2018 | Ford F-150 Cars & Trucks
How do I clear the error codes on a 2001 Dodge Ram 3500 diesel?
You will need a hand-held obd2 scanner to clear the codes. Advanced Auto store will do it for free if you have one in your area. Other part stores will also do it for free.
You can disconnect the negative battery cable for 10 minutes and replace it, but it doesn't always work. Sometimes the codes are stored in memory and require the hand-held obd2 to clear them
Apr 19, 2010 | 2001 Dodge Ram 3500 Truck
Hands free icon always visible even when not in use.
Reset your Phone to the Default settings and see what happens
Jun 12, 2009 | Sony Ericsson XPERIA X1 Smartphone
Passcode for hands free parrot bluetooth device
The code is nearly always 0000, but if that doesn't work try 1234.
Mar 24, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Bluetooth issues
The solution was quite simple. Always give your new hands free kits the full charge before trying to use it. I never thought it would make that much of a difference but it obviously does. I feel terrible about all the hands free kits i have taken back as faulty.
Feb 18, 2008 | LG Shine KE970 Cellular Phone
Innovage 69420210126 Phone Logo
63 people viewed this question
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Damen Wong
Damen Wong
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
