Question about Vivitar ViviCam 5100 Digital Camera
Vivitar5100 format I was trying to ture my pictures from vert. to horiz..I went to the setup menu and saw FORMAT and thought this is the place to ture my pictures WRONG it seems that I have lost all 132 pictures.Is there anything I can do to regain them please help.
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off)and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems. If you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link: If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many. One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below: You can try the demo to see what you can recover before buying. Remember - Do NOT try & write anything back to the card until you can recovered your pictures to your PC safely! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 26, 2007
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
The camera says memory full when I try to take a picture even thought I just put a new memory card it in
You probably need to format your card. Look thru the menu on your camera...there should be a place on the help menu, which allows you to format your card.
Aug 21, 2011 | Polaroid iZone 300 Digital Camera
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Zenith tv picture is larger than screen
There are Horizontal and Vertical size controls behind the back cover that need to be adjusted using a hand held tool. This adjustment requires a trained tech. High Voltage from the set is dangerous.
However, there maybe some limited controls that may help through the on screen menu.
To get into the setup menu, you need the original Remote that came with the TV.
Hold the Menu Key down until a box appears in the corner of the screen, then press 9,8,7,6 Enter. this takes you to the service menu. Just scroll through the items to find Horiz Size and Vert Size.
Good luck
Dec 30, 2009 | Zenith H32G48S TV
There's a very narrow line (white) appears at the very top of the screen when the picture scene is mostly black. A verticle adjustment should fix it but where is it?? RCA F36TF720
it may be an electrolytic cap problem as most newer sets are controlled by an I.C. chip for horiz and vert timing/size/linerity
Nov 02, 2009 | RCA F36TF720 36" TV
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Convergence problem
most likely u have to change the convergance ic's that is the first thing u do and it should work if u are not loosing any vert or horiz drive going to your convergence ic now there is one other thing that the have on the bigscreens if it is a magnavox they take the horiz drive from the if board it has a mirco chip on it that seends the horiz blanking p to the convergence board. hope this will hp
Sep 06, 2008 | Philips 55PP9401 55" Rear Projection...
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
Convergence problem w/ red horizontal only-WS-65807
Do not try to adjust anything yet!! Adjustments do not get out of alighnment all of a suddenly. The convergence adjustments are there to do minor aging alighnments. I would first check for bad solder connections on the convergence IC's first.
Sep 08, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Vivitar ViviCam 5100 Digital Camera Logo
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
