Question about Pentax ME Super 35mm SLR Camera
Pentax ME SuperProgram shutter button doesn't release shutter
My niece is starting a photography course and I was going to loan her my camera which has been kept unused for years in a nylon bag in a closet. I can't find the manual and I cocked the shutter arm to see if there was any film loaded and regardless of which position I set the dial settings, the shutter button was not tripping. I opened the camera and there was no film inside. I manually moved the takeup spool and tried again but no change. I pressed the rewind release button on the bottom of the case but that didn't help and now that button remains in a depressed state. It's been a while and the battery(s) may be dead. Could this be the problem? Is the shutter on this model not mechanically tripped. I also tried setting it to 125X, vaguely recalling something about when the batteries are dead you can still take pictures that way, but no good. Are there batteries under the hand grip as well as the meter battery on the bottom of the case? This was my 3rd Pentax SLR and I never had any problems with my original SpotMatic, or the Me Super. I can't find a copy of the manual at Pentax.com to see about the battery(s). Thanks
  • 1 more comment
  • russw Aug 27, 2007
    Thanks for your information and the link (although the pdf doesn't load, however he does have a zip of jpg page scans).
    To be clear, I'm having this problem issue with both a Pentax Super Program and a ME Super. I put new batteries in the Me Super and the light meter LED's were working. I then tries advancing the film crank and it stopped as I had already wound it before (again with no film in the camera) and NOW it won't click the shutter.
    Note it was just cranking and cranking without coming to a stop before this. I manually moved the mirror pin to check the mirror movement and now it stays in the open position and won't return to it's normal position for viewing through the viewfinder. I vaguely remember having done this before long long ago but I don't have a good light to see the mechanism clearly.
    So, now both cameras won't "click" the shutter regardless of the shutter setting. As I originally mentioned, I haven't used these cameras since the late 80's. Do they just go to xxxx with non-use? I just "dug out" my original SpotMatic and hopefully it will work if I can find a 1.35v battery. I remember it used a cloth shutter.
    Suggestion welcome and thanks
    Why does this come up as a solved problem now. I didn't click a wrong button did I when posting??
  • Anonymous Feb 08, 2008
    Shutter does not cock on advancing the film. Fitted fresh batteries. Tried all shutter speeds and aperatures.
    President:
  • 1,114 Answers
It is possible that the mirror is stuck in th "up" position. You should be able to fire the shutter as you say on the 125x setting with no batteries. You can download the manual from the link below: http://mcfaddenphoto.com/camera_manuals/pdf/ME_Super.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 26, 2007
SOURCE:
Long exposure? how dp you acoomplish this using the pentax k-1000
You will need an external shutter release that locks. Connect the shutter release, then on the camera set the shutter dial to B (bulb). With the shutter release cable fire the camera and lock the plunger, or hold it down. Using a shutter release cable you are less likely to cause camera shake. Of course have the camera on a tripod or something steady.
Jan 27, 2014 | Pentax K1000 35mm SLR Camera
How can i find timer in my Pentax K200d camera?
Press the Fn button to bring up the Fn menu. Press up on the four-way controller to bring up the [Drive Mode] screen. Use left/right to select the one-handed clock. Press down, then use left/right to select the one-handed clock (the one WITHOUT the 2s caption). Press OK. Start the self-timer by fully pressing the shutter release button
It's all on page 117-118 of the manual you can download at
http://www.pentaximaging.com/files/product/k200dE.pdf
Jan 04, 2011 | Pentax K200D Digital Camera with 18-55mm...
I have not used my camera in about 2 years just bought a battery yesterday. 2 problems. 1)When I look in the view finder it is black, yes the cover is off. 2)If I keep the battery in the camera, the...
Are your battery contacts clean ? ? Can you open the film area and see if the mirror is up ? If the mirror is up, then you have problems. The camera did not go throught it's shutter program and the mirror has not been released to go down. Major repair that is way more expensive then a replacement camera. Same with the battery, something inside is not turning off (completing the shutter function) You can go with film or digital as the Pentax lenses work with both. If you change to Pentax (Ricoh ownes it now) digital, the old film flashes will not work. Need a newer digital Pentax flash for a Pentax digital camera.
Feb 09, 2018 | Pentax PZ-70 QD 35mm SLR Camera
I have a Pentax ME Super and whenever I press the shutter button down, regardless of whether it's in auto, manual or 125x mode the shutter will stay open for the amount of time my finger holds down the...
One old camera. You have an electronic shutter and mechanical (backup) so you may have a dead electronic shutter. I would check the battery and contacts. If they are good... the shutter is bad. You have a standard K-mount body, any lenes will fit any Pentax camera, film or digital. The lenses will go on more modern Pentax bodies but will not auto-focus if on an AF body. These bodies are some 25+ years old, many places are selling them for $30 or so.. there are just thousands out there. If you want to stick with film, go for a newer AF body and you can still manually focus.
Feb 01, 2018 | Pentax Program Plus 35mm SLR Camera
No instructions need to know how to operate
The Nikon MC-EU1 Remote Cord is an accessory available for the Nikon COOLPIX 880/885/990/995 4300/4500/5000/5400/5700/8700 cameras. The MC-EU1 Remote Cord is 80 cm long and allows the camera to be fired remotely like a cable release for a film-based camera.
The MC-EU1 Remote Cord's main function is to prevent camera shake. As well as the shutter release function, the MC-EU1 has the following functions.
1. operate the camera's zoom remotely,
2. advance or return images in the playback mode,
3. Controlling interval photography, automatically fire the cameras over a given interval.
Note this is the only Nikon remote cord available NIKON COOLPIX cameras and is only compatible with the cameras listed.
The Nikon MC-EU1 remote cord has two Interval modes, A and B
In Interval Mode A: the first photograph is taken at the start; and subsequent photographs taken at the specified time intervals, thereafter.
In Interval Mode B: the first photograph is not taken until the specified time interval has passed and subsequent photographs taken at the specified time intervals.
These modes can be selected by pressing the MODE button. The device cycles through settings in the order, Remote Mode, Interval Mode A, and Interval Mode B. When the Remote Mode is selected, the LCD panel displays Remote; when Interval Mode A is selected, Interval appears together with the letter A and Interval Mode B is indicated by Interval and the letter B.
The interval Modes, allow you to take photographs one after the other at a selected interval, which can be set in increments of one second to any value from two minutes to twenty-four hours. Interval modes are only available when the camera is in recording mode and cannot be used when the camera is in playback mode.
Setting the Interval
1. Setting the camera to recording mode and the remote cord to Interval Mode A or B, the interval setting will be shown in the remote cord LCD display. Items currently selected for editing will flash. Each time the selection (SEL.) button is pressed, the item selected will change as shown below.
Select the desired time by altering the settings (second [S], minute [M], or hour [H]) one at a time. While the item is flashing, press the down button to decrease the time set, or the up button to increase the time set. The value displayed will change by one each time either button is pressed.
2. After adjusting settings, press the selection button until the display is no longer flashing.
Starting Interval Mode Photography
• Half-pressing the remote shutter-release button has the same effect as half-pressing the shutter-release button on the camera, readying the camera to take a photograph. If the interval is set to less than two minutes when the shutter-release button is half-pressed, the interval display will flash. Choose an interval of two minutes or more.
• Full-pressing the remote shutter-release button has the same effect as full-pressing the shutter-release button on the camera, starting interval mode photography.
• When the camera enters interval mode, it will either take a picture and then begin the count to the next photograph (Interval Mode A), or begin the count to the first photograph (Interval Mode B). The Interval indicator in the LCD display will flash while interval mode is in effect.
Ending Interval Mode Photography
• Half-pressing the remote cord shutter-release button while an interval mode is in progress stops the interval photography.
• Photography will also stop should you run out of available space on the compact flash card; In this case, the number of exposures remaining displayed in the LCD panel will be 000.
The MC-EU1 has a feature that when the zoom button is pressed twice in rapid succesion, the camera will start zooming until this function is cancelled by pushing the button a third time. If this function is not cancelled, no other function is possible with the MC-EU1. If the MC-EU1 does not respond as expected please ensure you have not activated the zoom function.
Jan 02, 2010 | Nikon MC-EU1 LCD Remote Control
Film Advance Lever is loose, shutter wont work when I press the Shutter Release Button. viewfinder is black
If your viewfinder is black, the mirror on the film camera is up. That usually means the shutter system is out of whack... Repair would be too expensive. You can by a used Vivitar, Pentax body as a replacement as they use the same non AF K-mount lenses for pretty cheap. But again, they would be old cameras.
Oct 11, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
67 for Astro Photography
You may wish to choose a much older model which uses a mechanical shutter with BULB functionality. That way, you don't rely on the power in a battery to keep the shutter open for 20-90 minutes.
Finally, for this type of questions, I would also try the Photo.net forums - the guys over there know just about everything about photography!
Apr 11, 2008 | Pentax 67II Medium Format Camera
Will not auto focus
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Nov 11, 2005 | Nikon F4s 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
333 people viewed this question
Top Pentax Photography Experts
Bill Eager
Geoff Hone
Are you a Pentax Photography Expert? Answer questions, earn points and help others
