Do I disconnect at the washer or from the wall? And /what about the overflow - again at the washer or keep the overflow on
The pipes are connected to the water pipes there should be a red one and and blue one. or the taps on the pipes are sometimes coloured. turn the taps so that they are not running level with the pipe. or the other way than they are now. they will stop at the right point. unscrew the hoses at the pipe end white plastic ridged screw caps you might need a gripping spanner. make sure as you take each one off you do not loose the washers inside there. black rubber things, the drain should just lift out but have a bucket ready because when you put the pipe on the floor lots of water will come out of the pipe. hope that helps. liz
