Question about Sony PlayStation 2 (PS2) Console
Playstation two controller
I bought a used playstation 2 with controllers. when I play the games, the vibration function doesn't work on mine, but will on another persons unit. what am I doing wrong?
    Scholar:
  • 72 Answers
Its possible the connector on the PS2 has come loose on the inside of the unit. The other possibilty is that the connector on the end of the cable of your controller is dirty or loose. If its just the controller connector, try taking a cue tip and some rubbing alcohol and cleaning the connector on both the controller end and the ps2 end, just be sure that you don't turn on the PS2 until the connectors are completely dry. If you use rubbing alcohol it should take less than a couple mins for the alcohol to evaporate
Posted on Aug 26, 2007
SOURCE:
Get controller off vibration mode,
Press the (PS) button, Go to controller settings, Press X and Go down to vibration Function and turn off.
Jan 08, 2015 | Sony Playstation 3 (PS3) Console
Hey!!! I got 2 New PS3 Dualshock 3 controllers that were working perfectly and one day out of nowhere they don't vibrate anymore. I didn't change any settings or do anything for that matter. Please...
Try resetting the vibration on the controllers. press the PS button, Settings, Accessory settings. then controller Vibration functions, Vibration Function ON.
Jan 12, 2011 | Sony Dual Shock 3 Controller for...
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
Playstation game won't read controller
chances are you controller is broken if not it your controller port
Oct 05, 2009 | Sony PlayStation 2 Slimline Console
I have a fat ps2 with a rumble controler problem
just keep ure ps2 safely and always shining . so always clean ur ps2 and make the best use of controllers carefully
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
USB GAMEPAD NOT WORKING!!!
I used one like that for my windows xp home PC (It looks just like the Playstation 2 controller) and it worked with MAME (original arcade games that were downloaded on my computer) It comes with a little CD that has the drivers on it...Look on ebay..they are very cheap coming from China and Hong Kong
Apr 24, 2009 | Video Game Consoles & Games
Vibration function
Try a different game, either its the controller, the game, or worse would be your ps2 is busted.
Jun 11, 2008 | Sony PlayStation 2 (PS2) Console
Vibration malfuction
The controller will still function as normal,
But inside there is a BENT / CROOKED / weighted, spinning mechanism in one of the protruding grips... that often straightens or gets stuck.
The only way to fix it is to take it apart - EASY!
Putting it back together is - NOT!
firstly, spray the pins with a contact cleaner.
May 08, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 dualshock analog controller not vibrating
Usually, all dualshock controllers malfunction after a year or so. Do not be surprised.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Ps2
The special fuse inside the PlayStation unit is broken. If you need more info please advice.
Mar 31, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
