Question about Philips MMS 460 Computer Speakers
No sound new computer no sound from speakers but sound from headphones... drivers are installed... clueless...
I changed TDA1524A(Stereo-tone/volume control circuit)
Posted on Dec 18, 2007
  • 59 Answers
Most computers use the GREEN output jack on the sound card for playback...plug your headphones in the back where the speakers go...sound? Yes...then verify you ahve the speaker system put together correctly...bet you don't...note: self powered speakers must be plugged in to work (electrical plugged in). If no...then you got a bigger fish to fry... Good lUck
Posted on Aug 27, 2007
SHG7980 Windows 8 drivers not available
If there is a driver needed ?
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC.
The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa.
The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound.
Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel.
Double-click "Headphones."
If no "Headphones" option is available, double-click "Speakers."
Click "Properties" on the General tab.
Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable.
Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab.
Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume.
Go to the "Enhancements" tab.
Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device."
Click "OK" to close Headphones Properties or Speakers Properties.
Test the audio.
If the headphones fail to output sound, unplug the headphones from the computer.
Reconnect the headphones to the PC.
Headphone jacks are color-coded lime green on most PCs.
Look for the headphones symbol if the jacks are not color-coded.
Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa.
Test the headphones.
If headphones still won't emit sound, the sound card most likely requires replacement.
Replacing the Sound Card
Shut down the computer. Remove the power cord from the back of the PC.
Disconnect the keyboard, mouse, monitor and all other peripheral devices.
Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD.
Set the computer on its side.
Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer.
If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed.
Remove the new audio card from its protective packaging.
Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks.
Screw the card to the computer case.
Reassemble the computer.
Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer.
Plug the headphones into the new line-out jack.
Jul 10, 2013 | Intel Computers & Internet
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Dec 29, 2012 | Hitachi VisionDesk 1330 (1330-001) PC...
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
Mar 23, 2011 | Acer Aspire Z5700 PC Desktop
I have no speakers, trying to use headphones
possible causes:
  1. volume was muted on PC
  2. volume was too low
  3. plug to wrong jack
  4. faulty headphone
  5. audio driver was not installed (check Device Manager)
  6. faulty audio driver
  7. use the wrong device for sound playback (Control Panell > Sound and Audio Devices > Audio tab)
Jun 19, 2009 | Audio Players & Recorders
My computer does not regonize any audio devices
From a distance, it sounds like you do not have the sound card drivers installed. Since it is a SoundBlaster card, go to creative.com and download a utility that finds, indentifies, and then installs the drivers for your sound card. That should fix the problem. If not, then you have other issues going on with motherboard drivers not being installed installed.
Jun 06, 2009 | Audio Players & Recorders
Automatic not switch the headphone and notebook speaker
sound like u have to update your sound driver. try this link driver updater download it and install to your computer. scan your driver using after installing this software and then restart your computer. its work in acer laptop. might be it will work to your computer also.. cheers..
Mar 09, 2009 | Compaq Presario C700T Notebook
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
No sound from speakers
Hi, Did you install the sound driver in your new computer? That is the first issue you should try. If the little speaker appearr at the lower right of the screen then the spearkers should be ready to go.
Oct 09, 2006 | Boston Acoustics BA735 Computer Speakers
Philips MMS 460 Computer Speakers Logo
184 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
