Krups 574 Power Xtreme VI Premium Work Top Blender
Problem for Krups 574 Power Xtreme VI Premium Work Top Blender
I have a krups 574 blender. The male part of the
By p24 on Mar 28, 2009
I have a krups 574 blender. The male part of the gear that inserts into the jug is made of rubber and was shaved off one time when the jug was not properly attached before the blender was turned on. I would like to order the part which I believe is $10 but I believe I need to undo the screws at the bottom of the blender to detach the gear. The screws seem to require a special tool. How would I locate such a tool?
Pete
Best Solution
posted on Mar 28, 2009
Very Helpful)
p24
Rank: Apprentice
Rating: 100%, 2 votes
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 21, 2009
Not Rated)
THISWONTWORK
Rank: Apprentice
Rating: 0%, 0 votes
This method worked well. I was having a hard time cutting away the rubber gear so I let the motor do the work on its slowest setting and just held the utility knife fairly static to expose the metal disc that is what attached the gear to the threaded shaft.
Was this helpful?
Yes
No
Popular Solutions for Krups 574 Power Xtreme VI
Questions and Unsolved Problems for Krups 574 Power Xtreme VI
Do you recommend Krups 574 Power Xtreme VI Premium Work Top Blender?
Answer
Answer
motor not working and making noise osterizer blender
Answer
Hello my Jack LaLanne power juicer express needs a new pulp collector as the small notch that fits... (More)
Answer
All the points of the black plastic rotor on the base which turns the blades came off so the rotor... (More)
Answer
Describe your lid for Black and Decker Crush master BL12475G Problem I'm just missing the lid for... (More)
Answer
Hi, the blender doesnt work. When you press any button the motor or mechanisms don't work or move.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Blender Experts
Top Small Appliance Repairmen
in , CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
