Question about Electrolux EW1000i Front Load Washer
Electrolux front end loader
Bowl makes a bad noise when u turn it by hand and when wasing
How Old is the machine: Is it within the 5 year major parts cover? If so the drum bearings are covered.
Posted on Sep 02, 2007
SOURCE:
Electrolux front loader EFLW417SIW that will fill & run for 3 minutes then the time remaining goes to 1 min. And turns off. I have power cycled / unplugged the machine.
Heater problems abort the wash cycle and end the program. May be faulty heater. Does machine drain and spin on spin only cycle? check pump if not - or motor.
Oct 25, 2017 | Electrolux Washing Machines
I have a 12.5 hp Briggs and stratton lawn mower engine that will not start. It has fresh gas and a new spark plug. every time i try to crank it it makes a rattling noise
The rattling noise may or may not be related to the motor not starting, but I'd definitely figure out what's causing the noise first. Could be anything from busted ratchet pieces in the recoil mechanism to a piece of debris dragging across the flywheel fan blades to a loose coil to a busted connecting rod down to a broken governor, bad main bearing or loose blade. Since I can't hear the noise, I'd recommend first checking the one of those things that would definitely make a rattling noise and would definitely keep the motor from starting: Remove the spark plug and shine a penlight into the cylinder, noting the position of the piston. Pull the starter rope just enough to make the engine turn over partway. Repeat a few times. If the piston doesn't move, busted rod. That'd be both the source of the noise and why it won't start. If the piston does move, I'd work by process of elimination until I found and addressed the source of the noise. That done, make sure you have a good spark when you crank it. That done, the problem is almost certainly a dirty carb. If your carb has what appears to be a 1/2" nut holding the bowl on, either shut off the fuel valve (if your motor has one) or clamp the fuel line to the carb and remove the 1/2" nut from the bottom of the carb bowl. The "nut" is actually the main jet. Clean it and the bowl with carb cleaner, making sure the tiny holes in the nut/jet are squeaky clean. Reassemble, remove the clamp and try again. If still no go (or it's the older-style carb with screws holding the bowl on) you'll have to pull the carb and do a complete disassembly and cleaning. Dang this was a long-winded answer but I didn't have much to go on. Hope it helps.
Apr 05, 2016 | Murray Garden
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Feb 28, 2016 | Electrolux Washing Machines
My trton t90z makes a loud noise 15 secs after its turned off. Its the thermal switch. Should I get it replaced. Its 2 days old.
What makes u think its the thermal switch? normally the noise at beginning or end of cycle is caused by the compressor with bad springs, groumets, or not sure how to explain this but the freon sits in a round bowl like orifice and when its low there is usually a loud noise at end of and beginning of cycle. other words when goes off and comes on? ( this is usually due to moving the fridge on it side and not waiting long enough for oil to settle before turning on?
Apr 02, 2015 | Refrigerators
My hmw1260k started making a grinding noise ,after about a week it started making a banging noise then stopped spinning, i took off the back and saw the belt had come off and has stretched, do i just...
probably just the belt wearing. check if you can spin the bowl by hand easily. it could be that the bearings have seized, and this will cause the bowl to be very hard to move even by hand.
Oct 28, 2013 | Haier Washing Machines
Loud grinding noise front end while driving. Hub bearing? Started a few weeks ago but not so extreme and usual only when turning. Now it is a loud metal grinding sound almost constant and seems to get...
Probably so. When making a left hand turn, if the noise gets loader, it is the right side bearing. IE... putting more wieght on that side of the car.
Jun 01, 2013 | 2003 Chevrolet Avalanche
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
Electrolux EW1000i Front Load Washer Logo
159 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
