Question about Canon EOS-30 35mm SLR Camera
Film Rewind Hello I haven't set any custom function, batteries are new, never had this problem ever before...the film (a dx coded, 24 exp print film) is just not rewinding after its over. I accidentally opened it ...and must have fogged the film ...but I am more concerned now about the malfunction. Even tried the mid-roll rewind button, ...could hear the 'whirrrr' but the film counter does not count back, nor does the LCD line move in the display (as it does when film is rewound) and the film fails to rewind. Can you help to diagnose, please? Thanks
    Champion:
  • 217 Answers
Check the mechanism inside the film compartment, it may have a broken rewinding gear, if there's nothing broken clean the contact point inside the film compartment, use cotton buds and alcohol or fluid.
Posted on Sep 01, 2007
Hello, I have not been using my Pentax zX5n for a while. Recently I decided to use it again and was surprised to discover that after loading a new batteries that it would not start. Actually after loading...
Have the old batteries leaked in the battery compartment ? Also, when you removed the previous film, did you set the camera into rewind mode ? If not, you have probably damaged the winding motor beyond economical repair.
May 08, 2017 | Pentax ZX-5 35mm SLR Camera
How so I inaert film
I'm not familiar with your exact model so what follows is generic to many film SLR cameras and assumes that the camera is already empty:-
Open the back of the camera by pulling upwards the rewind crank on the top left hand end of the camera (as viewed from behind). The back of the camera should pop open a little, open it all the way.
Before fitting the film, check if the film can is DX coded. It will have DX printed on it somewhere if it is, but will also have a large area bare metal squares interspaced with printed black squares or rectangles. if the film is not DX coded then look for an ISO number, ASA number or DIN number and note it somewhere.
Drop the roll of film into the space at the left of the camera, and push the rewind crank back down to secure the film canister. Pull out the film leader across to the right hand end of the camera. Often there are printed instructions or diagrams showing what to do. Your camera probably has an easy loading system in which you pull the film leader until it's level with a printed line and then close the camera back until it clicks.
Turn the camera on, normally it will staert whirring as it autoloads the fil onto the take up spool. If successful the number one will appear in the film counter display within a few seconds. If not then open the camera back and try again.
What you do next depends on whether the film is DX coded or not. There will either be a dial or a menu item which allows you to set the film speed, for DX coded films set the control to DX or to AUTO. If the film is a rare non DX-coded one then you need to set the speed manually. Select the correct ISO number in the menu. If your film had an ASA number then use it as an ISO number and if it had a DIN number then look up DIN to ISO conversion online.
If this has solved your problem then please return the favour by rating my answer, thanks.
Jun 30, 2009 | Minolta Dynax 404Si Film Camera
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
What does A ERR mean?
There are several situations when this message happens and the camera locks up, and almost none of them has anything to do with the cause stated in the camera manual: film DX coding error. (If it is truly a DX-coding error, manually setting the ISO speed of the film should solve the problem. This could happen in cold weather.) Scenario One: when using Alkaline batteries and the batteries are almost exhausted, and yet one continues to shoot. The battery may not have enough power to complete the shutter firing operation (which usually includes: mirror up, close down diaphragm, shutter fire, mirror down, open diaphragm, advance film, and charge the shutter for next frame). The camera could be lock up in the middle of the operation, left with a dimmed viewfinder. Usually an indication appears quite early if one pays attention: when the batteries are almost exhausted, the film advance becomes noticeably slow. In normal situation film advance is very fast and one cannot distinguish it from other noise such as mirror flipping. When the batteries almost exhausted, the film-advance could take almost 1 second, and the noise of film advancing has been mistakenly identified by some as "beep". I think those is the result of over-adjustment for the Premature Battery Indication problem. This scenario is particular to using alkaline batteries, due to the peculiar behavior of the alkaline battery: even when its power is almost exhausted, it still has a pretty high voltage. Solution: replace the batteries and fire the shutter once should solve the problem. I am pretty sure this is normal, since it happened to me several times, and I once deliberately repeated this happening. Scenario Two: At the end of a roll, when the remaining film is too short for one more frame but long enough to fool the camera, the camera could end up with "Err" message. Solution: rewind the film and load with the new one, and possibly fire the shutter once could solve the problem. (This has never happened to me, but summarized from other’s reports.) Scenario Three: I've heard of two reports: happened in the middle of a roll, with sufficient battery power. I have no idea what’s going on. (Could be really a DX-coding problem, which does not necessarily occur just at the beginning of a roll.) Solution: probably should send the camera in for a check. (Also, both reports of this problem occurs while using Kodachrome films.)
Oct 15, 2008 | Nikon N90S 35mm SLR Camera
How do you use the multi-exp button
Simply hold down (in) the Multi Exp button while advancing the rewind lever to re-**** the shutter--which allows the camera to hold the film stationary to make 2nd or 3rd or 4th exposure to the frame of film...however many exposures that you desire to that frame of film.
Sep 08, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Nikon FM: Shutter release button will not allow me to take another photo and I'm only on frame 15 of a roll of 24. The film advance lever does not move the film, but it does open all the way to the right...
The FM is a mechanical camera, the batteries only power the metering system. Sometimes what happens is when you buy film say in 4 roll packages, they give you 3 24 exps and a 12 exp. I suggest that you rewind the roll and check this. You will only lose the last frames if the roll is indeed a 24 exp.
Jun 08, 2008 | Nikon Cameras
Nikon F60 Film rewind uncoded film help
Most manual cameras have a button to release the film on the bottom of the camera, push the button in and turn the rewind crank (left side of the top of the camera) until you feel the crank suddenly turning much easier.
Oct 04, 2007 | Nikon F60 35mm SLR Camera
Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Apr 25, 2007 | Pentax MZ-50 35mm SLR Camera
Canon EOS-30 35mm SLR Camera Logo
129 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Jerry Greenberg
Jerry Greenberg
Are you a Canon Photography Expert? Answer questions, earn points and help others
