Question about Akai LCT3201TD 32 in. LCD Television
Setting up ant1 or ant2
When you go into setup for tv it wont let you go to that screen it is grayed out
    Novelist:
  • 192 Answers
Try pushing the source button on the remote until it goes to ANT 1 or ANT 2, then that part of the menu will not be grayed out. (Sidenote) If you take a pair of rabbit ears and attach them to the antenna input that says air, you can receive high definition local channels. Autoprogram the set at night, that is when most channels that send that signal, usually, show it at night. If it continues, reply to this post and I'll respond.
Posted on Aug 26, 2007
SOURCE:
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
Sony kv-32hs420 screen mode doesnt work
Display ratio usually is a setup choice but bear in mind that old movies and old TV programs will display in 4:3 ratio. Remotes usually have no control over screen size.
Dec 28, 2013 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
ABV511: how do you set the clock...
1. Switch your TV to Video mode (the one you use to watch VCR tapes)
2. Press VCR on the Allegro remote control.
3. Press Setup/Menu button.
4. The top item in the main Menu on the screen is Clock.
5. Follow the instructions on the screen using the gray triangular buttons on the remote to navigate
May 17, 2010 | Allegro ABV511
Pioneer PDP-6020 FD, Menu items grayed, no HMG after firmware upd
I have the same issue - Pioneer told me the local repair shop could reset the firmware, I paid the $90 service call and they could not fix anything. For a 18 month old $5000 TV they now want me to replace the digital board for around $500.
Sep 10, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Ctc 179 service program
No need for the answer I have the setup instructions for the rca tv. I am a tv and computer technician and always carry a sheet with these instructions as I work for company like Sears on tv, projection tv, audio and other electronics, thanks for the help.
Dec 30, 2008 | RCA G35831AT 35" TV
Samsung 46" LED flat screen TV cannot acsess Caption.
Call the tech support for your TV set. There may be a servcie setup fault, or a component failed that controls the placement of the text, or it may even be a user setup that can be done.
If there is a failure, the set will have to be serviced.
I would guess that you refered to the user manual for any possiblity that there is a setup for the placement of the text...
Jerry G.
Dec 03, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Picture is too big for screen
Go into the setup menu of the TV, and you'll find a category called DISPLAY or ZOOM. That's where you can change the aspect ratio so that it fits on the screen. You'll probably get a gray band on the top and bottom of the screen due to the re-sizing.
Sep 02, 2007 | Televison & Video
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
Akai LCT3201TD 32 in. LCD Television Logo
132 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
